Cracked coolant line. Nightmare repair!
12-11-2015, 12:23 PM | #1 |
Rep 1,834
Drives: 08 E90 335xi TiAg
Last week while replacing my serpentine belt and pullies I made a bonehead mistake. managed to crack a large coolant line that runs from the reservoir to the eater pump, across/along the subframe cross member to the AT trans cooler and ending up under thr charge pipe connecting to the heater (?)!!
Talk about the worst possible thing to crack!! I cracked it while jacking up the front end from the center jack point. I used a block of wood between the jack and jack point and positioned it a little off...as I got to the high point the wood started to make this terrible cracking and the car shifted and "crunch"!!....all my coolant dumped out the middle of the car like a faucet on full blast. To say I had a little panic attack is an understatement. Turns out this hard plastic section of the octopus of a coolant line sits right in front of the jack point. I cracked the shit out of it! After inspecting it and finding the part online I quickly realized I was in for a real PITA job replacing it. Once the part arrived I began pulling the damaged one out...not too bad until you get to thr driver side where it snakes up under the PS/AC pun/compressor. BMW managed to place a single brace/screw in the most difficult to reach spot I've ever come across on this car. Alternator removal and lower bolt? Piece of cake! Lower OFH bolt next to the manifold? Please?! I had to order a set of flexible socket/nut driver extensions off Amazon just to prepare to attempt to reach that lone bastard of a screw. Once I got down there to get it out I tried to reach it from thr top, bottom, side etc. My hand could barely even get in there to toucb it let alone get a socket on it. I ended up cutting the coolant line and cut away at the mounting point using a hand saw. After an hour of trying and loads if cursing BMW enginners I managed to snake two sections of flexible extensions with a wobble/elbow on the end down in there from the top and finally got the socket on there by some miracle. Used milwaukee mini impact and the little bastard broke free!! Pure bliss. Once the coolant line was out...which was quite the ordeal removing all the hose comextions from the water pump, reservoir etc I got the new one in. I tried for another hour to get the new line secured in that ridiculous spot and gave up. It is pretty stable and the line is rigid hard plastic so it isn't going anywhere. Filled it up, bled it and thank god zero leaks....back in business. Moral of the story...be very careful using that front jack point or you may suffer the same fate. Some pics of my ordeal. This post has been therapeutic!
E90 2008 335xi - TiAg - AMS FMIC - BMW PE - BMS OCC - ER CP - KW V3 - Vorshlag Camber Plates - AG M359 18" PSS - Alpina Flash - RB PCV Valvle - AFE Intake - Walbro LPFP
12-11-2015, 02:19 PM | #3 | |
Rep 1,834
Makes me very curious what a dealer would charge to replace/fix it...I'm thinking they would remove the alternator, PS pump, AC compressor, vaccum canisters, fmic and all hoses/intake stuff. Likely would not be cheap! Think I will call them up and ask for an estimate. |
12-11-2015, 02:27 PM | #4 |
BimmerPost Supporting Vendor
24503
Rep 191,503
Mine cracked on its own couple months ago ... glad you got it fixed
12-11-2015, 02:47 PM | #5 |
Rep 1,834
12-11-2015, 02:48 PM | #6 | |
24503
Rep 191,503
Took them less than half an hour
12-11-2015, 04:08 PM | #7 |
Rep 1,834
12-12-2015, 08:37 AM | #8 |
Rep 217
It's really annoying these are one piece. I really wish you could just change out the connection then re attach the hose. I cracked the one that runs right up the front of the motor to the hpfp. It was a pain.
12-12-2015, 08:58 AM | #9 | |
Rep 688
I actually knicked the hard coolant line that runs at the top of the motor when doing my serpentine belt. All of a sudden tons of coolant starts shooting out and thus my day was ruined, a simple 1 hour task on my day off turned into a mess. I was so pissed. |
12-12-2015, 10:04 AM | #10 |
3442
Rep 79,211
I've almost came to the conlcusion there is no way to work on this car without breaking something else LOL
Plus tasks that should take X amount of time always need to be tripled. |
12-12-2015, 12:41 PM | #11 | |
Rep 1,834
Took a nice long drive yesterday and the car is running well so job is a success. Oh...FYI I broke my belly pan/skid plate when this happened...well a good chunk of it. I found an OEM style replacement online for $30??!!! $36 shipped. It isn't OEM but says it is a direct replacement. I'll post a link as it is over $100 cheaper than anywhere else. Nice reason to replace yours if it is as trashed as mine! |
12-12-2015, 12:43 PM | #12 |
Rep 1,834
Bingo! When I got down there to inspect the damage I thought...oh no sweat, just needs the hard plastic center section....then noticed the hose clamps were permanent. Thought I might have been able to saw it apart and use some hose clamps to splice the piece in but no dice wince the driver side is one piece plastic all the way up. Very frustrating design!
12-12-2015, 12:45 PM | #13 | |
Rep 1,834
However...that is part of the fun, IMO. I actually enjoy wrenching and spending time in the garage. Just would rather be upgrading and doing maintenance vs repairing and replacing expensive parts. Lmao. |
12-12-2015, 02:52 PM | #14 | |
Rep 1,643
2007 E92 335i MT
