335is VTT Stage 2+ turbos e70 logs
12-11-2015, 09:39 PM | #1 |
Rep 558
12-12-2015, 02:39 AM | #4 |
MR. Rocket
46
Rep 398
Drives: 2010 E92 335i M-Sport
I'm no expert at reading logs but your iat's aren't looking healthy at the end of the run.
|2010 E92 335i 6MT\\\M-Sport///225M 19" Rims, MHD PTF Stg 2+, Fuel IT Stage 2 LPFP, VRSF Downpipes, CDV Delete, ER CP & 5" IC, Forge DV, PE Modded Mufflers, BMS DCI & Cowl Delete, CYBA Tips, ST Coils, M3 Control Arms, E93 M3 Sway Bar, Michelin PSS|
12-12-2015, 10:22 AM | #7 |
Rep 554
Drives: E92 335i 6MT
Looks fine, start raising the load slowly and see how it does with more boost.
12-12-2015, 12:44 PM | #8 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
Did you have DSC completely off? You have a big throttle closure in 3rd.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
12-12-2015, 02:53 PM | #9 | |
184
Rep 1,702
Drives: Audi TTRS, 335is
Personally I'd get Stage 3 LPFP and PI. You wont have to worry about fueling and you will have plenty of headroom to push these harder if you want. He hit boost ceiling and throttle closed. |
12-12-2015, 03:16 PM | #10 |
Rep 779
MBoost is already out for INA0S, it was in the last update. Would you believe I have the same shift issues on it that I had when I tried IJE0S_IS with Mboost?
If you're interested artsoasis, I have a Maxboost module here never installed and probably won't be. It was one of the originals from Ken that I bought a month or two ago. |
12-12-2015, 03:22 PM | #11 | |
184
Rep 1,702
The physical Maxboost module is soon to be obsolete with the soft Maxboost coming. You will be able to scale it within the .bin itself. |
12-12-2015, 04:27 PM | #12 |
Rep 779
That was my thought, didn't matter where ceiling was set, multiple roms and TCU flashes so logic or something in the map impacting it.
I saw that. I originally got the module for the stockers, but ordered turbos so probably can't use more than 20psi until I upgrade the fuel system anyway, hoping it's out by then. |
12-12-2015, 06:08 PM | #13 |
Rep 316
get stage 3 lpfp and PI. hpfp dips down below 700. With the right fueling, you can push these even further.
12-12-2015, 07:15 PM | #14 |
Rep 3,553
Lots of power left on the table.
Stage 3 and pi Raise your boost ceiling (through mhd or jb4) Didn't say if you have inlets and outlets, but if not, both of those will help as well. |
12-13-2015, 08:57 AM | #15 |
Rep 558
I have inlets currently and was wondering if I had power left on the table with my current setup. I'll have port injection and stage 3 fuel pump in February.
Engine Mods: VTT stage 2+ Inlets + DCI Stage 2 fuel pump Intercooler Chargepipe Downpipes Diverter valves |
12-13-2015, 12:18 PM | #16 | |
Rep 1,084
12-14-2015, 10:22 AM | #17 | |
Rep 558
12-14-2015, 04:24 PM | #18 |
Rep 316
This is true LOL.
