Best Product for Treating Rubber Seals?
12-22-2015, 03:25 AM | #1 |
Rep 78
Hi,
Anyone advise a good product for treating rubber seals? everything that I have used only lasts a week before the annoying rubbing comes back to drive me mad! Any suggestions? |
12-22-2015, 03:35 AM | #2 |
Rep 828
A product called Gummi Pflege is good stuff. Also if you can get it, Shin Etsu Silicone Grease is even better. Used to use both on the rubber seals of my S2000's roof.
12-22-2015, 06:08 AM | #5 |
Rep 828
12-22-2015, 09:58 AM | #6 |
Rep 405
carbaflow or DUPONT KRYTOX GPL-105 The latter I've purchased from ebay. It really is the most reliable product to stop creaking on seals and other rubbing plastics.
12-23-2015, 02:26 PM | #7 |
Jeff
319
Rep 1,451
I have just put grease on the top of each door - the furry bit. Sometimes need to re-apply it, but the latest greasing has lasted 3 months or so without any creaking.
12-27-2015, 11:16 AM | #9 |
Rep 559
I used a plumbing lubricant for push-fit fittings about 6 years ago, Never had to do it again.It is silicone based lubricant for waste fittings with the rubber O rings.
12-30-2015, 09:04 AM | #11 |
Rep 559
Bartol Silicone lubricant. I used it on my e93 conv. roof seals when dealer failed to cure the problem. It comes in toothpaste tube size. Other manufacturers of push fit fittings may also supply it. Plumbing counter is a good place to start.
01-01-2016, 01:46 PM | #12 | |
Jeff
319
Rep 1,451
I would imagine that you could smear virtually anything that is similar to grease along the furry strip and it would improve things. |
