01-02-2016, 12:16 PM | #1 |
Rep 312
Non-Lighting Package, DRL with Headlights
I wasn't sure whether to post this in the cosmetic and lighting subforum or this one, but it seems to belong here more.
I do not have the lighting package, so the DRL is just the medial lamp of the two in the headlight unit. As soon as I turn on the headlights, the lateral lamp (headlight) turns on and the medial lamp (DRL) turns off. Is there any way to get the DRL to stay on when the headlights turn on? And if so, is it legal in CA? |
01-02-2016, 04:33 PM | #2 | |
Rep 5,262
01-08-2016, 05:18 PM | #3 |
Rep 312
In the lighting settings, there is only a choice for DRL on or off. I was wondering if it was possible to code the function of DRL to stay on when the headlights turn on, meaning there are 2 lamps per headlight housing that are lit.
01-08-2016, 08:17 PM | #4 | |
Rep 5,262
03-23-2016, 07:27 AM | #5 |
Coding ECU's remotely
448
Rep 1,179
Is it possible to code the halo's to stay on but not the rear lights for DRL?
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
03-23-2016, 09:13 AM | #6 | |
Rep 5,262
you can code them on with Rear DRL Yes REM MAPPING_TAGFAHRL_H_L_OUTPUT sl_l Enables rear DRL Rear DRL Yes REM MAPPING_TAGFAHRL_H_R_OUTPUT sl_r Enables rear DRL |
03-23-2016, 12:24 PM | #7 | ||
448
Rep 1,179
