01-27-2016, 09:11 AM | #1 |
Rep 417
Vibration and high pitch warble
I posted in the wheel and tire sub-form about the vibration I feel all over the car since I had my winter wheel and tire set put on starting at around 60 mph but really getting noticeable at around 70 mph. Unfortunately with work and Snowzilla, I haven't had a chance to get the wheel balance rechecked (but I haven't driven much either).
Testing out today whether I think the vibration is the roads or the balancing, while driving with the radio off, I also noticed a high pitch warble sound at about the same speeds. I tried in comfort and in sport modes to see if the change in rpm made a difference, and it did not. The sound didn't happen at the same rpm in lower gears either. So, the sound seems speed related. I'm about 25 miles from 1,200, so I'm going to take it in this week, but if anyone has any idea what this might be so I can tell the dealer to check it out it would be greatly appreciated.
Current: 2016 BMW M235i | 2013 BMW X1 xDrive28i (wife's)
Gone but not forgotten: 1992 Buick LeSaber Limited | 1999 Acura CL 3.0 | 2003 Volvo S60 2.4T | 2006 BMW x3 3.0i | 2009 Honda Fit Sport |
01-27-2016, 09:51 AM | #2 |
Rep 3,332
Is the warble noise just tire noise? Snow tires generally make more road noise than others because the tread blocks are deeper. Similar to how offroad tires make a racket on the highway.
For the vibration, it simply sounds like a wheel balance issue. Just to ask a potentially obvious question - given the blizzard, you don't have snow or ice melted inside your wheels do you? Snow stuck inside the wheel will throw off balance dramatically and cause quite a bit of vibration.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
01-27-2016, 10:15 AM | #4 | |
Rep 417
No snow or ice in the wheel. I've been parked in a garage and today was my first day driving since the blizzard started. No loss in tire pressure over the last couple of weeks. How likely is it to have a bent rim but to maintain tire pressure? I've confirmed that my dealership does road force balancing, so if it is bent hopefully they can catch it.
01-27-2016, 10:26 AM | #5 |
Rep 3,332
It's very easy to have a bent rim that will still hold air. The rubber bead of the tire is pretty good at conforming to the shape once it's on there.
But, since I assume you were driving on the same wheels prior to putting on the snow tires (without any issues) unless it's been bent since then, it likely would've shown up previously. If not, just tell the service manager you can take him for a ride to show him. Often times they aren't going to go above the speed limit in a customer car for obvious reasons, so saying "I get a shimmy around 100" will probably go undiagnosed. One last assumption, are you using the factory wheels or aftermarket wheels? If you are using aftermarket wheels that are not hubcentric, it's possible the wheel is not properly centered on the hub.
01-27-2016, 10:54 AM | #7 | ||
Rep 417
Of course it could be a manufacturing issue. But from what I understand, road force balancing should be able to detect bent or out-of-round wheels. The dealer that mounted and balanced my wheels and tires confirmed they use road force balancing, and didn't make any mention of any issues with the wheels or tires. If they can't figure this problem out the next time I'm there, I'm going to look into taking it to another dealer or a specialty shop.
01-27-2016, 10:56 AM | #8 |
Rep 8,942
If it's the first time bend is unlikely. That said, for future knowledge, I was driving around on 3 bent rims for a month or two before getting to dealer. No loss of pressure. Sounds like balancing as others have said since brand new.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
01-27-2016, 03:21 PM | #9 |
Rep 5,580
Any vibration in steering wheel? ( but, vibration in seat) If no inspect rear wheels, notice if the adhesive weights attached appear excessively large or attached in more then one location on the circumference of the wheel.
The warble description seems like tread induced. But if you can check under car to make sure all the underbody cladding is tightly screwed in. |
01-27-2016, 03:21 PM | #10 |
Rep 825
I bought a snow wheel, tire and TPMS set up for my truck. I had a horrible vibration and noise. I took it back 4 times for balance and once to check the alignment which was good. I felt the bad tire was in the rear so the shop rotated the tires then I had a shake in the steering wheel. The tire shop finally put the tires on a Hunter Road Force balancer and found I had two tires that were way out of spec. They replaced the tires and the truck is a smooth ride now. Perhaps the Road Force machine would tell if you had wheel or tire issues.
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
01-27-2016, 03:46 PM | #11 |
Rep 8,942
One other thing to try although doubt this would be the issue - did the shop mount the wheels properly in the car? Assume you've got a square setup but there's def a drivers side vs passenger side difference as the tires are meant to go one way based on tread pattern. Not sure if that would produce the effect you're describing, or any effect at all. Think more traction issue.
2022 Macan S
01-27-2016, 05:07 PM | #12 | ||
Rep 417
01-27-2016, 05:11 PM | #13 | |||
Rep 8,942
2022 Macan S
01-27-2016, 10:57 PM | #14 |
Rep 417
So I checked the rotational direction on the tires and they are all right. I also checked the adhesive wheel weights. There aren't any on the front driver side and rear passenger side. There are only two on the rear driver side. But the front passenger side:
and
01-28-2016, 09:01 AM | #16 |
Rep 417
I also noticed today that the vibration and warble are worse in the morning when my car has been sitting in a garage all night rather than a colder surface lot all day. Maybe this suggests a tire issue? Warmer tires worse than colder tires? Seems to make sense at least for the warble if a warmer tire has a slightly larger contact patch that may cause more tire noise. Not sure how a warmer, softer tire would cause more vibration than a colder, stiffer tire.
01-29-2016, 09:00 AM | #17 |
Rep 417
I've got an appointment to bring the car in early next week (the dealer had to order a trim piece they broke when they loaded my summer tires into the car so they can replace it at the same time when I bring the car in). Fingers crossed they can get this fixed.
Noticed another thing. The vibration and noise are really prevalent with my foot on the gas, even when not accelerating but maintaining constant speed. As soon as I take my foot off the gas, the noise and vibration reduce significantly or maybe even go away. I'm going into a downward spiral now. Starting to think the engine is idling rougher too. This is freaking me out a bit. I'm hoping that this doesn't turn into something major with the transmission or other parts of the drive train.
01-29-2016, 09:42 AM | #18 | |
Rep 8,942
02-04-2016, 12:49 PM | #19 |
Rep 417
So I got the car in to get checked. I was supposed to take it in next week (missed my appointment this week because of work), but yesterday the car developed a new noise at around 40 mph. Freaked me out because at first it was kind of a grinding/crunching noise, but then it became more of a high pitched wheeze. Definitely more steady sounding than the warble at 70 mph. Both sounds begin to immediately subside or disappear after I take my foot off the gas, even if speed is maintained, and pick back up when putting my foot back on the gas.
I also ran through 5th-8th gears at 70 mph and the sound stayed the same. Kind of a relief, since that seems to suggest it might not be a transmission issue. Got a call from my service adviser. He said that the "tires were definitely out of balance" which sucks since they supposedly balanced them twice already (think I'll be finding another dealer for service). But, they attribute the noise to the winter tires. Going to pick it up tonight. Hopefully the balancing helped. I have my doubts.
02-18-2016, 03:15 PM | #20 |
Rep 417
So the balancing got rid of the vibration. Great that it took them three tries to get it right. Anyway, I got a second opinion on the noises. I took a ride with my sales guy (different dealership than the one that was servicing my car), who is an enthusiast himself and really knowledgeable. He put the car through some driving test and said he didn't feel anything out of the ordinary, and is of the opinion that it is just tire noise. Before we went out on the road, he did note that the tire pressures were off and fixed that for me. The tires were filled to even pressure all around, between the door sticker numbers. In other words, the backs were low and the fronts were high.
While I still have to deal with the noise, at least I'm at ease about it. What I did learn from this process is that I'm taking my car elsewhere to get serviced.
02-18-2016, 03:33 PM | #21 | |
Rep 8,942
02-18-2016, 05:07 PM | #22 |
Rep 417
When I took my m235 in for what I called a post-break in service, the service adviser was so confused as to why the M2 post-break in service wasn't covered under my service plan. I get it if you work at an independent shop that sees cars of all makes and models. But if you are brand specific, it would be nice to at least know the basic differences between the cars. I mean, I've already paid for most of the service for the next 4ish years, I'd like to know that the people doing it are treating my car right.
