02-14-2016, 10:22 PM | #1 |
Rep 1,563
Turbo Part number leak (different than M235i)?
Not sure if this means anything or not, but I'm bored so what the heck. Was watching this BMW M2 Coupe Technical Animations Powertrain Video:
Beginning around 58 seconds they have a view of the turbo. Interesting enough, they took the time to actually render a part number on the turbo. It's the only part in the video in which they did that on. Best as I can make out it reads: 18621015007 A M B2 1 12/10 Then on the engraved blue sticker, it reads: 18621015064 The M235i part number is 11657643115 Who knows if it means anything, but is it possible the M after the part number indicates a M specific turbo? Anyone have pics of the S55 turbos to see if that is on there as well? I am still guessing it will be the same/similar turbo to the M235i, but it is interesting to me they chose to render the part number. Easter egg? Here's to hoping! |
02-14-2016, 10:36 PM | #2 |
Rep 1,563
For reference, I had a 2014 X1 35i N55 and the turbo part number engraved on the borg warner turbo was 18621015060a. That was a pneumatic wastegate, for what it's worth.
02-14-2016, 11:02 PM | #3 |
Rep 499
It's the same turbo as M235i
M2 has better integrated turbo into ex manifold for rapid warm up, top piston ring from M3, same spark plugs, bigger injectors, forged steel crank, same bearings as M3, same but single air intake like M3 with m sport hole at bottom of air box The B series version would use: 11658637041 |
FSociety3816.50 |
02-14-2016, 11:14 PM | #4 | |
Rep 1,563
02-15-2016, 03:48 AM | #9 |
Rep 146
It just does not seem logical it's the same turbo. A stage one tune on the 235i typically yields only about 40hp so right at what the M2 is rated at stock. So right from the factory it's basically maxed out?? It has bigger injectors but that is not needed if it's the same turbo and capacity.. Likely the turbine or compressor or at least slightly upgraded. Maybe I'm just overly optimistic.
02-15-2016, 06:19 AM | #10 |
Rep 1,644
Just because it has a different part number doesn't mean its different. Many parts get revised slightly or switch manufacturers mid model year and get a part number update.
02-15-2016, 02:51 PM | #11 |
Rep 329
Drives: Ex BMW owner, will return soon
02-18-2016, 10:56 PM | #12 |
IG @bmwF9xG80
3817
Rep 7,595
Drives: G80 M3, X4M, G07 X7m50
Cant wait till tuners still poking these and we really find out what its capable of.
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
02-19-2016, 12:42 AM | #13 | |
Rep 11,785
02-19-2016, 12:45 PM | #14 |
Rep 763
I haven't had a chance to read every review. Has a single reporter even investigated this? This is a pretty important component for me and it seems odd so many people aren't interested
02-19-2016, 01:13 PM | #15 | |
Rep 2,404
Given that BMW has taken the time to make press releases noting all of the engine differences (new block, pistons, etc.), and hasn't noted a larger turbo ...I'd say that's at least some evidence of it being the same. No worries, a Pure Stage 2 may very well bolt right up.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
02-19-2016, 03:51 PM | #17 | |
Rep 146
02-20-2016, 06:03 AM | #20 | |
Rep 536
Looks like the same turbo then?
02-21-2016, 08:23 AM | #21 |
Rep 499
There was a German part supplier site saying that 11657643115 was the turbo lader for the M2 and X4 M40i but it has curiously disappeared
It could be same turbo housing/part number with different revision... Internals may be upgraded/better There's that video of the dude in his tuned 1M and he couldn't catch up to the M2 even tho the M2 was a proto... Maybe the proto had the upgraded S55 in it for th CSL Maybe the B engine will be avail with the LCI If you like the 228 and love the M235i you will got to have the M2 until something more bodacious comes out |
02-21-2016, 10:12 AM | #22 | |
Rep 3,888
The M2 is missing, but X4 M40iX is there. |
