03-04-2016, 05:54 PM | #1 |
Rep 22
SOLD FS -AFE Scorcher Module for N20/26
$250.00. Free shipping anywhere in the US. Put up to 38 hp and 49 lbs. x ft. torque to your N20/N26 today! The aFe Power SCORCHER Module is designed to alter the pressure sensor signals to increase turbo boost to an optimum level throughout the entire RPM range. The result is a harmonious balance between power, throttle response and drivability. This module provides a hassle-free installation with no cutting, drilling or splicing required during the 30 minute installation time. Factory electronic accessories are not affected by installing the Scorcher module. Direct Plug In Power: This simple and safe plug and play module adds instant power by altering pressure sensor signals to increase boost to an optimum level throughout the entire RPM range. Blue L.E.D. Power light: This module comes with a built-in blue L.E.D. light to show your module is powered up and functioning correctly. High Precision and Reliability: Scorcher modules are 100% tested, have output protection on all signals and are built to a 0.1% tolerance on components in critical areas. Signal filtering is used for a smooth response. These modules work great on vehicles in stock trim but are optimized to maximum performance with use of aFe Power performance parts (intakes, filters, exhaust, etc.). High Quality Materials: aFe Scorcher modules use OE style "all weather" connectors which require no modification to your factory harness, providing a secure factory-style fit and hassle-free installation. The housing is constructed of aluminum with a hard coat black anodized finish and uses Automotive grade TXL wire with high heat and chemical resistance. Scorcher Modules come with a 2-year limited warranty. Note #1: Not legal for sale in California nor for use on California-registered vehicles. Note #2: aFe does not recommend to use with any other tuners or modules. Also Fits: 2014-2016 BMW 128i/ix (F20/21) L4-2.0L (t) N20 2014-2016 BMW 228i/ix/220i (F22/23) 14-16 L4-2.0L (t) N20 2013-2016 BMW 320i/ix (F30/31/34) L4-2.0L (turbo) N20/N26 2012-2016 BMW 328ix (F30) L4-2.0L (turbo) N20/N26 2013-2016 BMW 328i/ix (F31/34) L4-2.0L (turbo) N20/N26 2014-2016 BMW 420i/ix (F32/33) L4-2.0L (turbo) N20/N26 2014-2016 BMW 428i/ix (F32/33/36) L4-2.0L (turbo) N20/N26 2010-2016 BMW 528i/ix (F10/11/18) L4-2.0L (t) N20 2012-2015 BMW X1 28i/ix (E84) L4-2.0L (t) N20 2013-2016 BMW X3 28i/ix L4-2.0L (turbo) N20 2015-2016 BMW X4 28ix (F26) L4-2.0L (t) N20 2011-2016 BMW Z4 28i L4-2.0L (turbo) N20 Last edited by txchas; 04-07-2016 at 08:02 AM.. |
