Boost Leak: 30ff Need a little help
03-16-2016, 10:12 PM | #1 |
Rep 102
Hi, I'm trying to track down a boost leak which is progressively getting worse as time goes on...
I used to get and hold 18psi on an MHD tune with the occasional 30ff but lately get the dreaded 30ff /yellow engine symbol and can't get past 8psi while hardly pushing the car....I have recently replaced ALL of vacuum hoses even the ones running to wastegates and under engine cover. I am running an ER Chargepipe and Tial BOV (yes I remembered the O-ring) I've read all of the previous posts and have tried both the Smoke (grape swishers) test as well as the Air Compressor/ spray soap / listen for leaks test. Smoke test was inconclusive never saw any smoke after trying to pump several lit cigars through the system. Air Compressor test showed no leaks. Sprayed everything down multiple times even the intercooler pipes under the car. HERE IS THE ONLY THING I DID FIND.....while useing a compressor leak test from 5 to 10 psi once the system pressurizes I hear a loud air leak behind the engine on the Turbo side. I have put my hand as far back as I can but cannot feel any air leaking around the rear wastegate. Is this my leak? Where is it coming from? How can I fix it? Any thoughts? Or am I way off base here? Thanks |
03-16-2016, 11:44 PM | #3 |
BimECU
193
Rep 759
logs?
03-17-2016, 05:52 AM | #4 | |
Rep 2,020
335i e92 TPC 19Ts
03-17-2016, 06:16 AM | #5 | |
Rep 102
I guess I could try getting a boost solenoid and swapping it out with one or both to see if they are bad. Those things aren't cheap been putting it off. I will try to grab a log this morning and get it posted up. Thanks for the suggestions guys |
03-17-2016, 08:50 AM | #6 |
Rep 102
Here is a log from this morning. Yes it triggered 30ff code. Only reaching 8psi
http://www.datazap.me/u/clownaround/...a=4-25&mark=28 |
03-17-2016, 08:56 AM | #7 |
Rep 1,497
Check turbo inlets front and back and also check the turbo side coupler that connects to intercooler and upper turbo pipe on passanger side. If you have a after market intercooler and this clamp wasn't positioned right that will always cause a boost leak
03-17-2016, 09:20 AM | #8 |
Rep 102
Unfortunately its hard to get a visual on the inlets. Although the sound of air leaking does appear to becoming from the area of the rear turbo. Its quite loud and will eventually stop, once most of the air is out of the pressurized system during a compressor test. I am running a stock intercooler and stock turbos.
03-17-2016, 09:25 AM | #9 |
Rep 102
Took the chargepipe off as well as the intercooler connections under the car yeasterday. Wiped everything down performed a soap spray compressor test and reseated everything back together. No visible air leaks or noises other than the sound of air escaping behind the engine somewhere. If I could only look back there or get to it easier..
03-17-2016, 12:24 PM | #10 | |
Rep 2,020
Solenoid...there is a good way to check its operation, no need to just replace them yet. Try searching otherwise I can post the procedure and values to expect. Just did this.
335i e92 TPC 19Ts
03-18-2016, 06:48 AM | #11 |
Rep 102
The more I read about faulty boost solenoids the more I feel this may be the root of my problem. I'm going to see If I can test them out. I just need to find a vacuum guage.
03-18-2016, 08:34 AM | #12 |
Rep 666
If it's not the boost solenoids, then your wastegate vacuum actuators are bad.
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
