03-22-2016, 11:30 PM | #1 |
Rep 765
Side Skirts Blades
Got a new set of side skirts blades (splitters) and since I trew the boxes away, can't tell which is left or right. Already looked for part # on the splitters but it has none on either blades, Need help
03-23-2016, 03:57 PM | #3 |
Rep 417
I don't think a lot of people have these, although I've been thinking about it. I haven't seen them in person, but does it matter? Are they contoured or shaped such that flipping them over changes them? Maybe some pics would help people figure out what's what.
Current: 2016 BMW M235i | 2013 BMW X1 xDrive28i (wife's)
Gone but not forgotten: 1992 Buick LeSaber Limited | 1999 Acura CL 3.0 | 2003 Volvo S60 2.4T | 2006 BMW x3 3.0i | 2009 Honda Fit Sport Last edited by CanadianGatorBacon; 03-23-2016 at 04:04 PM.. |
03-23-2016, 04:28 PM | #4 |
Rep 269
How are they installed? Do they mount up with existing rocker panel mounting points? If so, it appears the mounting holes are not symmetrical front to back so you could compare the holes under the car to each blade.
This is a left rocker panel: Note the gap in the mounting points as you approach the front of the car. Seems like that would correspond to the gap in the mounting holes of the side blade: Might be worth crawling around beside your car a bit and just comparing parts to find out. I've been considering those myself for a while... be sure and post some pictures once you're installed. |
03-23-2016, 10:41 PM | #5 |
Rep 765
I have checked trying both blades on the same side and they appear to fit either one.
Uridian; They mount via 3m tape that goes the entire length and in one of the ends it has an additional double sided tape that is about 2/3" long. After is installed by the tape then you have to drill little holes into the side skirt and use the plastic pop rivets that comes in the kit. This week end will try to mount them or if anyone that already has them installed can post a pic from below showing one of the ends, front or back and what side then I can go from there... |
03-24-2016, 08:55 AM | #6 |
Rep 167
I installed these 3 weeks ago, if you look very close you can see the blade is a bit thicker towards the front and gets thinner as you get closer to the back of the car. Also iirc the front of the blade, there is a small indent.
Also when installing, be VERY careful as the 3M tape is EXTREMELY strong and if you stick it on the car after using the adhesion promoter it is a pain to realign. |
05-06-2016, 10:33 PM | #11 |
Rep 622
Pic of painted side splitter bladess
Here are pics of ones I had custom painted & installed myself. I will tell you this - they gather road dirt after riding around on wet roads. Put a couple of coats of good wax on them.
Pull the trigger - you'll be happy you did. These things add a great visual touch, for sure.
2017 M2 | MGM | 6SPD Std | RWD | MP Exhaust | CSF FMIC | Active Autowerke DP w/ HF CAT | FTP Charge & Boost Pipes | Fortune Auto series 500 7k/14k coilovers | CDT Audio ES Gold Fronts & HD series Rear | Richland Forged Project Nurburg RF-GT4 Wheels | AudioControl LC-6.1200 | JL Audio TWK 88 | CF Goodies
Cptnstephie1.50 |
05-08-2016, 12:03 AM | #12 | |
Rep 647
05-08-2016, 02:27 AM | #13 |
Rep 622
Here are some pics I posted a little bit ago. The diffuser part of the rear balance is painted orange. The color is BMW's Valencia Orange. It is more orange than the reddish-orange you see in some of the pics. More like a slightly handle new(er) penny.
http://www.2addicts.com/forums/showthread.php?t=1253893 Jim
05-08-2016, 02:30 AM | #14 |
Rep 622
I just notice the orange part of the diffuser is barely noticeable. I will post another better pic once the sun comes out again here in CT. Been cloudy/rainy for over a week, very damned day!
05-08-2016, 04:21 PM | #15 |
Rep 622
More pics of the diffuser for you
Here you go!! Hope this gives you a good idea of how contrasting paint schemes look. The folks that did this for me came highly recommended. And let me tell ya - it's perfect. Straight lines, no over-spray - PERFECT.
(Just an FYI - no scratches on the bumper or diffuser. All reflections. I know how to wax a car. heh heh)
05-08-2016, 11:27 PM | #18 |
Rep 622
Price of the blades
Go to ebay & look up sunmotorsbmwparts (seller). Best prices for genuine BMW parts, including M Performance. (Example - I got the MP exhaust for $790; SS finishers for $170 for both.)
I don't recall how much the blades were because Brian @ sunmotors packaged them with the rear diffuser for $530 total & didn't show separate price. I'd probably guess $350 for the diffuser & $180 for the blades. And it's free shipping. And they ship FAST FAST FAST, packaged very well. Everyone in the general 2 series forums talks about sunmotors. QUOTE=kd0t;19899812]How much are the blades?[/QUOTE]
05-14-2016, 05:08 PM | #20 | |
Rep 244
Post some pics after you install them. |
05-15-2016, 10:45 AM | #21 |
Rep 647
I dont have any intentions of painting these parts. I will leave them in their current state.. I would gladly post pics ater install
05-15-2016, 02:20 PM | #22 | |
Rep 1,151
Drives: F90 M5 Comp (Evolve Tune)
