03-28-2016, 11:21 AM | #1 |
Administrator
41124
Rep 21,245
Corner-by-Corner Comparison of BMW M2 vs M4 on Hockenheimring
BIMMERPOST NEWS Corner-by-Corner Comparison of BMW M2 vs M4 on Hockenheimring Here's a great corner-by-corner analysis of the BMW M2 vs M4 on the Hockenheimring (short track), compiled by DeDe. These stats come from the fastest lap of each car as driven by Sport Auto. The driver was Uwe Sener. The top values are for the M4 and bottom ones for the M2. We can see how well the cars compare in terms of corner speed, lateral G forces, and top speed at the end of the straight. The two M coupes show themselves to be fairly evenly matched on the short track. |
03-30-2016, 02:38 PM | #2 |
Rep 788
Interesting that the M4 was faster through almost ever corner, by up to 6km/hr, but only had a .2sec/lap advantage.
And had a lower top speed? After a straight where it carried more speed through the corner? Something doesn't add up... |
03-30-2016, 02:41 PM | #3 | |
S0THPAW
8730
Rep 7,847
Cheers Robin |
03-30-2016, 02:43 PM | #4 |
Rep 156
Drives: 2010 e82 n52
Perhaps it was the weight factor...lighter engine, lighter body, faster speeeeeed.
03-30-2016, 02:44 PM | #5 | |
CalcioGuy
50
Rep 124
Waiting for my 2019 M2 Comp. in september!
03-30-2016, 02:52 PM | #6 |
Rep 777
It's not clear if the values on top are for the M4 or the M2. If they are the M4, it won because of quicker acceleration to higher speeds in the long straights -- it appears the M2 took curves at a faster speed. At the end of one straight the M2 had a higher top speed as well. Weird.
03-30-2016, 03:03 PM | #7 | ||
Rep 5,110
I have just looked at my Sport Auto 4/2016 issue where the M2 Hockenheim lap was published. All of the statistics on the bottom fields match the M2 numbers for that lap. |
03-30-2016, 03:09 PM | #8 |
Rep 8,641
Lol, how would the M2 even have a straightline advantage? I think there may be some driver skill going on here.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
03-30-2016, 03:13 PM | #9 |
Rep 480
One would need to take two different drivers that each has done 100 laps on the track with their respective vehicle only and then compare average speed in corners.
If you take a driver that swaps cars over the course of one day, there are a lot of variables and factors at play that tell more about the driver than the car. Muscle memory, perception of grip, familiarity with the suspension and limits... confusing both the brain and muscle and butt dynos. Nevertheless it makes sense the M2 is faster in corners either way. |
03-30-2016, 03:13 PM | #10 |
Rep 422
The M2 is a wonderful car, and these are primarily the reasons why it is close to the M4.
1) The M4 has problems putting down the power. Having traction control on, the power is cut to much, having the traction control off, or in MDM the car becomes a handful. 2) The M2 weighs less, giving it an advantage in almost every aspect such as, acceleration, braking, cornering, etc. Still, its not enough to over come the M4's power once it is put down. Remember, less is more This just goes to show that having more power means nothing if you can not utilize it properly. Imagine, a M2 with M4 power, or even if the M2 had about 30 more horsepower to close the gap between the 2, and I can imagine the M2 would be faster on this circuit.
2004 GT3 (Track and weekend toy) 2016 Cayenne (Daily driver) 2011 Turbo PDK (Retired) 2013 M5 Black Sapphire( Retired ) |
03-30-2016, 03:27 PM | #11 | |
Rep 2,176
03-30-2016, 03:29 PM | #12 | |
Rep 5,110
03-30-2016, 03:34 PM | #14 |
Rep 5,110
03-30-2016, 04:04 PM | #16 |
Rep 422
Adding all wheel drive will change the characteristics of the car completely. In short though, it will give more traction to the M4 coming out of the corner, and ability to put down more power to the ground. The initial turn in though, would be interesting. I am sure initial turn in understeer can be dialed out by BMW relying on sophisticated xDrive systems. Don't forget though, this is once again, adding weight.
03-30-2016, 05:00 PM | #18 | |
Rep 2,679
03-30-2016, 05:05 PM | #19 |
Rep 1,271
So the M3/M4 needs wider tires and a bit of a front spoiler and rear spoiler.
A good set of Ohlin's, JB4 tune. I know there are many M2 fans and its a nice car, with an interior that needs to be ripped out. There is nothing different from the 235 aside from stitching. That said, M3/M4 rocks would take a RUF instead. LOL. M2 only if was for free. Last edited by Ghostriderf80; 03-30-2016 at 05:09 PM.. Reason: grammar poor |
03-30-2016, 05:21 PM | #20 | ||
Rep 788
03-30-2016, 05:31 PM | #22 | |
Rep 2,370
That should all count as interior, no?
Soon. |
