04-10-2016, 04:03 PM | #1 |
Rep 2,560
Drives: Rapidly from A to B
New owners, how much clearance is there?
Asking someone who has already taken delivery. I'd like to put 265s in front and 285s in the rear on stock wheels. This will give me more gription for less $s (simply buy 285s and take the stock 265s and mount them in front) and also give me better protection for the wheels. Can you measure clearance between:
The front strut and the wheel/tire. Outer edge of the wheel/tire to inner edge of the front fender. Rear shock and the wheel/tire. Outer edge of the wheel/tire to inner edge of the rear fender. Picking my car up in 2 weeks as the performance center! Last edited by Pyrat 2; 04-10-2016 at 05:38 PM.. |
04-10-2016, 08:03 PM | #3 |
Rep 1,963
These tires shouldnt hit the suspension since it shares it with the M4. I'm worried about the liners and fender.
Current
AW BMW M2 Past VO BMW 1M |
04-10-2016, 08:05 PM | #4 | |
Rep 2,560
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
04-11-2016, 09:01 AM | #5 |
Rep 3,954
There is big lip on the front fenders that I was checking out this weekend on the M2 that showed up at my dealer.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
04-12-2016, 06:36 PM | #6 | |
Rep 2,560
04-12-2016, 09:26 PM | #8 |
Rep 2,560
I'll order wheels with custom offsets if required. I squeezed 255/35 on the front of my 1 er with no fender work or crazy suspension mods. Had it down to the mm though with offset.
04-13-2016, 05:23 PM | #9 |
Not-So-New Member
103
Rep 61
That's absolutely a bad news for people like me who wanna go for some more aggressive offset......
Current: 2016 BMW ///M2 Black Sapphire Metallic / 6MT
SOLD: 2002 BMW ///M3 Matte Grey Metallic / SMG Core of WrongFitmentCocks |
04-16-2016, 12:32 PM | #10 |
Rep 1,963
Looked under the car last night and there is at least an inch between the rear tire and rear shock, probably more, didn't measure it. And this is to the dust cover over the shock so it has movement if it was rubbed. Tried to look at the front but it's too low to look under without lifting. Maybe I will drive up on ramps today to take a look.
Current
04-16-2016, 01:30 PM | #11 | |
Rep 2,560
04-16-2016, 09:17 PM | #12 | |
Rep 1,963
Now to the fender. I used a straight wood shim and put it on the outside of the fender then "eyeballed" it perpendicular to the ground. The edge of the tire was about even to the fender. (The rim protector portion of the PSS) If you follow the camber instead of straight up and down (nut on string method) you might have 5mm clearance ...Maybe even 8mm but I think it would give you the "flush" look...not quote hello flush though...lol! I will do the fronts tomorrow if I have time while the kids are sleeping. And remember, all of thsee measurements are on a stationary car.
Current
