injector replacement ?
04-12-2016, 11:23 PM | #1 |
Rep 394
I have 1 bad injector can i buy a used working one online and replace it without coding or do i still have to code it?
08 E82 135 -jpworkz 6870 top mount built motor
10 E92 M3 - Ess 650 Supercharger 18 BMW 530e - stock |
04-12-2016, 11:26 PM | #2 |
Rep 208
I say have it coded and make sure that you do not mix older index injectors with new ones I believe as long as it is series under 10 you can mix with 1-10 but series 12 def cant be mixed w earlier indexs.
04-13-2016, 12:03 AM | #4 |
Rep 208
There has been several revisions and the newer index 12 are supposed to be the best . I personally have all index 8 from my recall 4 yrs ago and have never had to replace even one so I say if its not broken dont fix it.
04-13-2016, 05:23 AM | #5 | |
Rep 310
Drives: 2007 BMW 335i M-Sport E90
I guess I can't mix 12 with 01. Is there any particular reason why you cannot mix them? Last edited by =C=; 04-13-2016 at 05:48 AM.. |
04-13-2016, 07:58 AM | #6 |
Rep 3,560
You can not mix injectors in the same bank.
But you can have different injectors in bank 1 vs bank 2 EDIT: I proved my statement wrong this past weekend. You CAN mix injectors in the banks. My bank 1 had all index 9 injectors and one was stuck open. Threw in a used one index 7 and all is good now. Also I checked bank 2 injectors and all three injectors in bank 2 were different index. What Jeff@TopGearSolutions suggested is a good practice but not absolutely necessary - "It's recommended to replace in banks of 3 injectors. Having 1 strong injector and 2 weak injectors will not ensure equal fuel to cylinders as your o2 sensors take an average of 3 cylinders to control fueling adjustments" Last edited by Wolf 335; 04-19-2016 at 08:41 AM.. |
04-13-2016, 09:21 AM | #7 |
3442
Rep 79,211
It's best practice to code them. Coding takes all of 5 minutes once you have the cable and INPA. Actually 5 minutes is a lie, it takes about 30 seconds.
It's recommended to replace in banks of 3 injectors. Having 1 strong injector and 2 weak injectors will not ensure equal fuel to cylinders as your o2 sensors take an average of 3 cylinders to control fueling adjustments. Replace 3 injectors at a minimum if you want to do it right. |
04-14-2016, 06:03 AM | #8 | |
Rep 310
I had a misfire on cly 1 however I decided to take each injector out and cleaned the tips. They look like new Car is running great and no misfires at all. I guess I'll need to buy 2 more if I ever do decide to replace bank 1 or 2 with the latest rev 1353 7585261-12 |
04-14-2016, 06:35 AM | #9 | |
Rep 281
04-14-2016, 09:45 AM | #10 | |
3442
Rep 79,211
Upgrade to 10 or change to XP if you have the means. I code with an old XP laptop seamlessly. |
04-17-2016, 09:43 AM | #11 |
Rep 281
Ha why didn't I think of upgrading to 10! I'm such an idiot sometimes.
04-19-2016, 03:04 AM | #12 |
Rep 310
Found this:
Injectors with index 10 and lower have a different calibration and construction than injectors with index 11 and higher. Because of this the injectors with index 10 and lower cannot be mixed with index 11 and higher in the same engine. |
