BIMMERPOST Universal Forums General BMW News and Cars Discussion N54 & N55 take a GTR on highway
      04-13-2016, 08:10 AM   #1
B@man335
B@man335's Avatar
Drives: 2009 BMW E90 335i Xdrive
Saw this on the internets and trying to figure out if this outcome is possible with the gtr being stock. Couldn't be driver mod so I'm guessing the guy wasn't really on the throttle. Just posting for discussion purposes
2009 Monaco Blue BMW 335 XDrive, Beyern 18s, KWv1, MHD, VRSF Full, ARM FMIC, BMS DCI, Stett CP, Forge DVs, Stage 2 LPFP, BMS OCC, (soon) M3 Rear Sway, VTT Stg 2, MMP Inlets
      04-13-2016, 08:51 AM   #2
MarkM5
Drives: B7 A4
Gtr actually aren't that quick after X amount of miles. Where they kill it is 0-100ish (give or take).
      04-13-2016, 09:03 AM   #3
GuidoK
#buildnotbought
GuidoK's Avatar
14295
Drives: Z4 3.0i ESS TS2+
an early base GTR has 485HP and weighs over 1700kg.
That's not an unobtainable spec for a tuned 335 I think.
Sure there is the matter of gear ratios and CW value etc, but a tuned 500+hp n54/n55 is not that uncommon and will be a good match for an early gtr
And the difference isnt that huge (in the end the gtr goes clearly off the throttle)
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
      04-13-2016, 09:10 AM   #4
Properstyle
Drives: 2011 e90 ZCP m3
my tuned only c63 was only beaten by 1 car on a fbo pump gas 09 gtr last year. the same year i ran a 2015 with mid pipe everything else stock and he only beat me from a 40 and 50 by 2 cars lenght. a Fulll bolt on 335i should beat a stock gtr with out issue off the hit, up top i'm not sure.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD
1994 300zx 2jz Swapped slicktop- The toy/track car
      04-13-2016, 09:11 AM   #5
B@man335
B@man335's Avatar
Hmmm I was under the impression that even the early gtrs were mid 500s stock.
