Blaupunkt Amp, High Pitch Frequency Noise thru speakers?
03-11-2008, 03:22 AM | #1 |
M Master
74
Rep 551
So I did a direct battery connection of the power wire and new ground line to the Blaupunk PNP555 amp last night rather than run it off the Harness that goes to the radio....All went well and the amp def pushes harder now..
1 big problem, About 20 min after the install, I notice an audible high pitched frequency interference noise thru the rear speakers that matches with my engine revs.. Im wondering if this could be a power line or grounding issue, though ive checked those connections already and everything else has been checked as well.. Any Clue? |
03-11-2008, 04:55 AM | #2 | |
Rep 13,023
Where's the amp installed? |
03-11-2008, 07:42 AM | #3 |
M Master
74
Rep 551
Behind the rear passenger seat.
Ive always had small frequency interuptions when my phone was sending an recieveing signals.. But this is directly related to the power wire. Im assuming it could be a few things. A. The power wire is being run along side the speaker cables on the amp, i will try to move this to the otherside and isolate the wire. B. The power wire is being run under the matting by the rear speaker, its possible that this is causing the interference as well Those are my ideas, what do you think? Also should I try to isolate the ground wire as well or would that have no adverse effects on this frequency signal im hearing thru the speakers? |
03-11-2008, 08:29 AM | #4 | |
Rep 13,023
03-12-2008, 06:22 PM | #5 |
M Master
74
Rep 551
Well No Luck.
I tried to remove the frequency noise many different ways.. Moved the power wire, shortenend the Ground wire, Unplugged the Original power wire from the harness.. Re-routed the main harness to the amp, seperated the speaker cables from everything. No Luck.. With the Battery Power, the frequency can be heard thru the "Rear Speakers" I tried everything.. No clue what could be causing it.. I went back to the OEM radio harness power, i did notice a very small frequency noise with this as well but not nearly as noticeable with the Strong Battery Powered cable.. Im guessing my car just doesnt like a strong power going to the amp.. Very wierd.. |
