04-24-2016, 10:58 AM | #1 |
Rep 100
Bmw f21 water pssenger side problem
hello, I have a problem in my bmw f21, today dismounting to install pdc front, I have met with the passenger side carpet full of water, someone can help me? not where it enters the water.
04-24-2016, 01:02 PM | #2 |
Rep 61
I had this on a different car some years avo. It was caused by a blocked drainage channel which had caused a backlog of rainwater and might have filled an air filter as well.
04-25-2016, 08:29 AM | #4 |
Rep 1,354
"The rain in Spain stays mainly in the plain."
http://f20.1addicts.com/forums/showthread.php?t=1176995
"Give piece a chance": contact your dealer. It shouldn't be expensive to fix (if not just free). |
04-25-2016, 09:29 AM | #5 | |
Rep 100
Thanks, but I want to fix it myself, I have to do? my car is September 2014, and this wet passenger side (right) front, the bottom of the carpet. |
04-25-2016, 11:31 AM | #6 |
Rep 100
it can also be ac clogged drain? someone can guide me to review all drains and grids replacement seen in previous post? I do not know where it is
04-25-2016, 12:32 PM | #7 |
Rep 1,354
Well, I watched the mechanic do it but I can barely remember details. The two points I noticed:
1. he used some access from under the car (started under the hood, like unlocked those, dived underneath to remove(?) and that was it); 2. it was really fast - just a few (a couple of?) minutes. These things are located near/under the front (windscreen) pillars. It's hard to locate them on a diagram, especially as I don't know how they look (like this? they must be some net filters I guess), but this one might be helpful/indicating: Various grommets / covers (refine the diagram selection for your car but it must be exactly the same I would guess). A textual description: Anybody got info on the grommet recall??. |
04-25-2016, 02:42 PM | #8 |
Rep 100
my car is September 2014, does not have those things, you have free hole. what else can look? You can have some clogged drain? where are desagues? I also made a diagnosis and mark me auc sensor error, I do not think it has anything to do?
04-26-2016, 07:35 AM | #11 |
Rep 100
I am not able to find the fault where it enters the water. also I have another problem, is heard a clang off when I start walking.
04-26-2016, 10:45 AM | #12 |
Rep 1,354
"At least you tried."
"You can't leave... Without saying "good night"." I don't know what exactly you refer to but I guess I heard something of the kind. I never worry: the car "lives on it's own". Do you really have to hate BMW service that much? With a warranty car you should have your concerns ready for them. |
04-26-2016, 09:57 PM | #14 |
Rep 1,354
My wild guess is a (single) clanking sound I sometimes hear from under the hood when leaving the car can be related to hot turbine (the heat shield?) cooling down. I usually drive moderately before a stop and this could be why it's an infrequent case.
05-21-2016, 04:55 AM | #17 |
Rep 100
drain ac is http://www.subirimagenes.com/imageda.../958843612.jpg circle red ?
05-21-2016, 10:08 AM | #18 | |
Rep 1,354
05-21-2016, 10:19 AM | #19 | |
Rep 100
yes, but it is not connected there |
06-16-2016, 01:42 PM | #22 |
Rep 100
Hello, after several months, still have the problem, I put fogger and no smoke is seen outside the passenger compartment, carpet is still wet, now it makes more heat on the street and carpet is dry, but the problem remains and no what else to try and do things.
