05-05-2016, 03:22 PM | #1 |
BimmerPost Supporting Vendor
3885
Rep 54,481
Drives: F80 M3
Ohlins Road & Track BMW F8X M2 M3 M4 BMS MR40S1 Black Friday Day Sale!
This is the latest step in the Öhlins Racing automotive philosophy for your F87 M2
– Road&Track by Öhlins. A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street Cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrifi cing comfort in your day-to-day transports. The time of compromises is over! We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide. FEATURES General Front Rear > DFV (Dual Flow Valve) > Rebuildable > Corrosion salt spray tested (ISO 9227) > 2 year limited warranty > McPherson strut > Single bleed adjuster > Spring preload adjuster (approx. 10 mm lower than standard) > Coil springs 90 N/mm standard > Dustcovers > Use with original top mounts > Conventional shock absorber > Single bleed adjuster > Separate spring preload adjuster (approx. 10 mm lower than standard) > Coil springs 190 standard > Dustcovers > Use with original top mounts BMS MR40/BMS MR40S1 You can only substitute one pair of Swift springs or a full set of Ohlins springs at retail price. Second pair of Swift springs at 20% off of retail. 80/160 & 70/140 Ohlins springs are very popular. Exceptional pricing from now until the end of the business day on Sept. 30th. 2023 PM for details! Looking for Ohlins for your other vehicles? PM us for a quote! Order here: https://hpautosport.com/product/ohli...m4-bms-mr40s1/ Last edited by HP Autosport; 04-26-2024 at 01:02 PM.. |
09-27-2016, 04:25 PM | #11 |
3885
Rep 54,481
Drives: F80 M3
11-06-2016, 01:16 PM | #21 |
3885
Rep 54,481
Drives: F80 M3
We can supply lower rate rear Swift springs at no additional charge!
