05-07-2016, 08:19 AM | #1 |
Rep 347
Kart Racing.
New track has a 2 hour endurance race coming up and me and 4 friends are joining the fun. I have done the high speed karts once and the rest of my team at least once, all at another track. This place claims 50mph. I did some searching on the web but didn't find a lot of tips. Any cart specific advice for the race? These are the rental karts we are using.
05-07-2016, 12:41 PM | #4 |
Rep 1,575
get those forearms stronger. no aids in the steering department, if your forearms arn't stronger/conditioned, arm pump will set in pretty quickly
2.0l ecosmackkaa
05-07-2016, 12:59 PM | #5 | |
Bergspyder
1582
Rep 1,249
Yes...you need to find spots to let the kart roll free. You have to free it up as much as you can. If you are putting input in you are binding it up. Solid rear axle you know. Get it turned and then find any little straight you can let it run free and use that time to relax your arms as well. The tighter the seat the better. Find the the two or three corners that lead onto the longest straight and do everything possible to maximize corner exit speed in those corners.
05-07-2016, 01:36 PM | #6 |
Know's a guy that know's a guy...
5654
Rep 1,905
No antilock braking either. You MUST drive the kart with a solid working knowledge of the track. It will get loose in a hurry at the slightest tap of the brakes.
05-07-2016, 01:51 PM | #7 | |
Custom User Title
1139
Rep 675
I went out for some laps in a fast kart and it was so fast and exhilarating after being used to slower electric karts that I put all my focus into surviving and at times forget to breath. Agree completely with the comment about forearms. |
05-07-2016, 06:57 PM | #8 |
Rep 347
Only time I did karts the brakes grabbed at differnt times and if you thought about turning while braking you spun.
05-07-2016, 06:58 PM | #9 | ||
Rep 347
Any my scrawny rib cage was bruised from The seat. Quote:
05-07-2016, 07:28 PM | #10 | |
Rep 700
05-08-2016, 12:22 AM | #12 | |
Rep 1,848
Even though you're driving a vehicle that weighs what you do, has a 100% locked "diff" (actually a chassis that raises the inside wheel when you crank the steering), a CRAZY steering ratio and a CG that's basically ON the ground, the real issue concerning your adaptation actually has nothing to do with the kart, since they're pretty intuitive to drive. The ACTUAL issue is the tires. They don't respond even slightly like a street legal tire, the grip will be higher but the response to pushing is a lot less forgiving. The ones you drive on will probably be old and heat cycled since new kart tires are expensive, but it won't matter and you'll still have a lot of fun. Also, if your ribs don't hurt you're not doing it right. |
05-08-2016, 12:47 AM | #13 |
powerhouse
742
Rep 1,628
Drives: 2014 Porsche 981 CS
No fucks abt this thread after a few drinks and didn't ready any of it BUT I will stay that I plan on hitting some karts in Irvine within the next few weeks and I'm pumped. Thanks for the reminder!!!
no signature. except for this one.
05-08-2016, 11:45 AM | #15 |
Lofty
3477
Rep 849
05-09-2016, 12:59 AM | #16 |
Rep 1,140
Drives: Something something racecar
Apex everything.
05-09-2016, 10:50 AM | #18 | |
Bergspyder
1582
Rep 1,249
If the seat doesn't squeeze you hard when you get in it is too big. You want no slack or you basically get slammed side to side in the loose seat. You want NO gap side to side so you become part of the kart. You can even bring a big stiff foam block if you are scrawny and jam it along side. ( I never had scrawny as an issue....I wish!) Pick up front of kart (you probably cant at fun kart tracks as those are built STRONG for stupid people) and try to slide it left or right. You will have a hard time as the rears are grippy and on a solid axle. The energy you put into trying to turn, even slightly, is scrubbed off by the front wheels. So you have to let it roll free and find its happy place...this is when you breathe and relax!!! In fact in the corners the binding is critical as well as you need to corner hard enough and fast enough to un-weight the inside rear wheel and let it scrub. (no differential, something HAS to scrub or it WONT turn). If you ease into a turn at a slow pace you never unload that inside wheel and the kart pushes like a pig. Your turn in should be focusing on getting the weight transferred so it will turn and then on exit getting the kart freed up with little steering input. And to repeat to lower lap times focus on getting OUT of the corners leading on to the straights that are the longest. I used to race KT100 sprint karts (and Spec E30 and an RZ350 and autocrossed a bunch of other stuff.)
05-09-2016, 10:57 AM | #19 | ||
5654
Rep 1,905
I had opportunity to go Karting with a fellow BP OT regular - I was sore for DAYS afterwards. My legs (Quads) and ribs felt like I had been 10 rounds with Mike Tyson - my arms and shoulders were fine however. |
