Have you removed your vacuum canisters? Any ill effects?
05-25-2016, 05:39 PM | #1 |
Bob Saget
356
Rep 2,229
So there was a recent debate in this thread http://www.e90post.com/forums/showthread.php?t=1209274 about removing your vacuum cans. I understand @twisted tuning has removed his and some other people on the "other" forums have as well.
So 2 days ago I removed mine. I did pre and post logs at WOT, startup, and in all gears under WOT & just normal cruising... My consensus is (at my psi level on my stock snails) that I have had no side effects and the car behaves as if nothing has happened. I am enjoying the added space in my engine bay as well. But I wanted to hear from you all what your thoughts on this are. Why are you keeping your canisters? Why did you remove your canisters? Etc...
In memory of Robert E. Flynn (AR)
05-25-2016, 05:56 PM | #3 |
Bob Saget
356
Rep 2,229
Right I have heard this before. I will also admit that the logic makes sense... However, I have seen BMW over engineer some things.
05-25-2016, 05:56 PM | #4 |
Rep 212
that's a misconception. many manufacturers add stuff to cars that in real world environment are not needed. this is nothing new. just because a car comes with something does not mean it's a necessity or the best design.
05-25-2016, 06:01 PM | #5 |
Rep 110
Did the waste gate rattle go away quicker upon start up?
Interested in doing this for awhile. And was wondering if removing them would have an effect in reducing start up rattle. How about decel rattle? |
05-25-2016, 06:02 PM | #6 |
Rep 212
never have had rattle on my car so I personally can't comment on that
05-25-2016, 06:04 PM | #7 |
Bob Saget
356
Rep 2,229
I have no rattle. SO I am not sure. My car sounds the same upon startup and WOT decel
05-25-2016, 06:39 PM | #9 | |
Rep 243
what exactly is everyone referring to when they say this? Off the top of my head, i can't think of a single thing BMW "over engineered" to a point where it's cool to just remove it. |
05-25-2016, 06:39 PM | #10 |
Bob Saget
356
Rep 2,229
Have you ran any test on your own vehicle pre and post vacuum can removal? Or are you name calling with a dumb and dumber reference simply because you disagree with the OP.
I created this thread to find more people that are able to quantifiably reason with others and have hard evidence that the vacuum cans aren't over engineering and truly do have a purpose. I'd show my pre and post logs but there's no difference in them. |
05-25-2016, 06:41 PM | #11 | |
Bob Saget
356
Rep 2,229
When setting the cruise control, a white "dash" appears from no where to signify you've set your cruise here. Should I continue the list? |
05-25-2016, 06:44 PM | #12 | |
Rep 243
tell me more about how we should all go back to the stone-age with non-electric seats on our street cars. Maybe ditch the power windows too and work on that forearm strength. Are you also implying we should remove our TPMS and install lexus' version instead? |
05-25-2016, 06:47 PM | #13 | |
Bob Saget
356
Rep 2,229
And yes, they over engineered the electric seats. If you've ever removed a bmw seat and tore it down revealing the motors and mechanics within the seat frame you'd understand why I say this. Further implicated by the sheer weight of the bmw seats due to over engineering. |
05-25-2016, 06:50 PM | #14 | |
Rep 243
Can you explain your expertise in seat mechanics and tell me exactly why BMW's seats are "over-engineered" to a point where it makes more sense to rip them out? |
05-25-2016, 06:53 PM | #15 | |
Bob Saget
356
Rep 2,229
I'd like to hear from both sides of the fence. Why those that kept the cans. And why those that removed the cans. |
05-25-2016, 06:59 PM | #16 | |
Rep 243
sometimes i think people just screw with things for the sake of having something to do. |
05-25-2016, 07:05 PM | #17 |
Rep 128
I have mine removed due to the shitty plastic nipples. My initial plan was to fit the metal barbs in a day or two, but thanks to procrastination and a tad of laziness, it has been more than a month. Have not faced any problems since I removed it though.
I have searched high and low regarding this but have not found anything constructive. My suggestion is to replace it with the metal barbs whenever you have time, and be safe and happy :P
________E90 335i 6MT mHD, VRSF DP, VRSF 7" FMIC, SSK, TWM knob, BAddictions DLB, CSF Rad, Rattling Turbos
05-25-2016, 07:12 PM | #18 |
Stuff and Things
39
Rep 103
For me, just about everything in my car is "over engineered" I'm not saying that's a bad thing. But I live in Northern CA where at it's hottest I've seen 120F and at its coldest 0F which by world round standards is really not that bad. The cars are designed to operate far outside of that range. So I appreciate BMW for doing that "engineering" I think what we have stumbled upon is maybe the best example of over engineering out there... I'm sure temperature has a dramatic effect on the efficiency of a vacuum system so they've added some parts to deal with those extreme situations. But "over" engineering is obviously a relative term. Based on J.Dubs info I'll happily remove them if I can come up with something cooler to put in their place lol.
05-26-2016, 07:19 AM | #20 | |
Guest
Rep n/a
Drives:
Better throw in that it's not "to spec" and "the engineers wasn't never intended for it to be like" just for good measure. I'm sure they were added to account for EVERY different type of driving condition, elevation, temperature, etc. and to fill in the gaps where a "worn" vacuum system in it's entirety wouldn't completely be up to par; especially under the care of a casual owner. As enthusiasts most here are far from that norm obviously, so excluding them probably won't make much of a difference in real world scenarios (as proven at least 100x by now). |
05-26-2016, 07:29 AM | #22 |
Rep 228
Drives: E92 07 335i
around town at part throttle, I noticed slow boost response when running without them for sure. going WOT or heavy throttle, I did not notice a difference like many others here.
