Schaeffer's Racing Oil
05-28-2016, 11:26 AM | #1 |
Rep 45
Anyone use #9000 Schaeffers Racing oil 5W 50? Just wondering if this is ok for summer for improved protection. Also I know OEM oil is 5w 30 and so would using a different SAE be ok? Friend of mine just started using it on on his e93 M3 after an engine rebuild as recommended by the tech that did the work. With the rod bearing failures starting to pop up more, thinking about making a switch. Thanks
JB4 G5 ISO, VRSF 3" DPs, BMS DCI, BMS OCC, VRSF CP w/Tial BOV, BoostConcepts Stage 2 LPFP, Secondary *** delete w/1792 resonators, VRSF 7in FMIC, 2in. inlets, Meth CM10
05-28-2016, 12:29 PM | #2 |
Rep 1,093
Don't use racing oil unless you are going to do oil analysis. Typically "real" racing oil lacks the detergent capacity to last more than a couple thousand miles as its assumed racing oil will be changed after each race (like 500 miles or less). The only way to know if it has the additives to last for street use is analysis.
On a side note nobody is less careless than me with oil changes and brand (I follow the indicator which I think is 15k). My last 3 cars were current 156k miles and counting, last car 125k miles and driving fine (put upgraded turbo on at 120k miles), car before that 145k miles. All modified longer than not and never once have had an oil related/long block issue. Drive the car! Parked with an crankcase full of contaminated oil where they don't get burned off is what kills engines/bearings. |
05-28-2016, 03:48 PM | #3 | |
Rep 380
Cam only...
