M2 Technical Topics > Suspension | Brakes | Chassis > BMW M Performance Coilovers and Rogue Engineering Suspension Parts
      06-03-2016, 09:30 PM   #1
Detailers Domain
BimmerPost Supporting Vendor
Detailers Domain's Avatar
Drives: 20 M2C / 22 X3MC
Some updates - Front Tension Arm Bushings and Sway bar links were replaced - suspension should handle a bit sharper with these mods, along side with the drop.
Car sitting pretty at Rogue Engineering
1M Race ready sitting next to the M2
Rogue Engineering Monoball Front Tension Arm Bushing
Rogue Engineering Adjustable Swaybar Links
Rogue Stainless Steel Brake Lines - custom made
One quick shot with of the suspension more coming.
s
Teasers courtesy of Ben at Rogue .... what a tease.
Just one shot of the suspension.
Check out the complete build here
      06-06-2016, 09:43 AM   #2
Jevi Javi
Dominican Republic
80
Drives: e46 M3 + G05 X5
when you get a chance. Would like to know how the ride comfort compares between MP coilovers vs stock suspension?
thanks!
      06-06-2016, 10:02 AM   #3
Detailers Domain
Will do I once I get the car back, lots of goodies going on the car right now.
      06-07-2016, 09:10 PM   #4
Detailers Domain
got some updated photos from Rogue Engineering prior to the car getting an alignment.
Nice clean install co's are in, ss brake lines are in, adjustable sway bar links.
car dropped wheels looking nice and on point.
BAN_M2C4186.50
      06-08-2016, 09:26 AM   #5
David@ActiveAutowerke
Drives: M2
Nice! From your swaybar link photo it looks like the front is set as low as it will go?
      06-08-2016, 10:46 AM   #6
Detailers Domain
it can go a little lower.
      07-17-2016, 07:34 PM   #7
ilyah
Drives: E92 335
looking great... any feedback on MP Coilover vs. stock suspension for DD?
Thanks
      07-23-2016, 02:37 PM   #8
parrnan
parrnan's Avatar
146
Drives: M2 LBB DCT with the great MPE
Very nice (suspension and wheels) !
The only ugly thing is the useless amber front bumper reflector. But thanks to iND there is a solution, at least when you live in the USA, outside USA the shipping cost are ruining the deal.
Imagine you nice car without the ugly things !
      07-23-2016, 10:02 PM   #9
Detailers Domain
LOL I should drop them a call on Monday and order them.
      08-03-2016, 10:40 AM   #10
paradoxical3
Hi,
Can you please comment on the Rogue tension arm bushings? On my old car, replacing the stock bushings (which are incredibly soft) with poly bushings made the car feel so much more alive. I am considering doing this to my M2 but am unsure if I want to go with monoball bushings or their press in aluminum/urethane ones.
What is NVH like with monoball bushings, and what is the expected lifespan of the monoball ones vs. the press in bushings?
Your m2 looks phenomenal. I had a deal to get those same BBS wheels before the seller backed out on me.
      08-03-2016, 01:29 PM   #11
Detailers Domain
it's much tigher I love them. where are you located...if you are around you can check out the cars back to back.
lmk maybe I can work a deal with you on the bbs I have a set available for sale brand new in the box.
      10-24-2016, 10:58 AM   #12
bignico_05
Drives: aw 135i m sport
Is the suspension set at the bmw recommended setting or you went lower?
      10-24-2016, 09:04 PM   #13
BurpZilla
Avid Car Enthusiast
BurpZilla's Avatar
Drives: 2017 Alpine White M2 6spd
beautiful! can you please PM me a price also?
History will never be forgotten
1992 Red Acura Legend 4dr, 2003 Daytona Blue Nissan, 350z 6spd, 2007 Black Audi B7 RS4 6spd
Current Girlfriends
Alpine White BMW M2 6spd; 2015 Arctic White Yukon XL Denali
      10-24-2016, 10:00 PM   #14
HP Autosport
Drives: F80 M3
Originally Posted by paradoxical3 View Post
Hi,
You have two options:
http://www.hpashop.com/Rogue-Enginee...e-monoball.htm
http://www.hpashop.com/Rogue-Enginee...t-F8x-M3-4.htm
jetbill199.00
      10-26-2016, 07:55 AM   #15
Detailers Domain
the settings are factory but to go lower in the rear we did not install the adjustable perches.
      10-26-2016, 11:39 AM   #16
Robban
Drives: M2
Understood, since it looked to low on the rear to be the Mperformance coilovers.
I have these also mounted and have the recommended height from BMW (595 mm and 600 mm).
On front I can drop additional 10 mm but on rear i have reached max.
To conclude: original vs Mperformance in lowering with standard recommended height;
Front: 25 mm (1") possible to go to 35 mm
Rear: 15-20 mm
Cheers
      10-26-2016, 11:41 AM   #17
Robban
Drives: M2
Rear: 15-20 mm
Cheers
Front was after the picture additionally lowered.
      10-26-2016, 12:34 PM   #18
ried
ried's Avatar
Drives: F31, F80
thanks!
x2.
      05-22-2019, 02:42 AM   #19
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
DD,
Did you fit adjustable sway bar links at the back as well or stay with OEM rear sway bar links ?
BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      06-01-2019, 08:04 PM   #20
c_w
Drives: M2
So is the rear spring sat in the stock upper cup and rubber pad?
      06-02-2019, 02:55 AM   #21
M Fifty
Drives: M2 & 330CI
Would have to be as there's no way to locate the top of the spring otherwise.
      06-02-2019, 03:06 AM   #22
M Fifty
Drives: M2 & 330CI
Originally Posted by ried View Post
x2.
The spring rates are higher, so this you notice. But, given that they are valved so that rumble strips (and lane markers, manhole covers and potholes...) are absorbed the same regardless of setting, it's more a case of how you want the car to feel.
if you use the track settings, there will be little to no weight transfer at license friendly speeds on the road, leading to a pretty anodyne driving experience in bends. How much softer you go depends on where and how you normally drive. I'm currently running 2 clicks softer all round than the recommended road settings as it makes it much easier to get the car moving around in bends on the relatively tight and twisty rural routes I try to take. Jetbill's shock dyno thread suggests that this setting is still stiffer than the stock dampers though...
ried793.00
Bee Pee1783.50
Tags
bmw m2, detailersdomain, rogue engineering
m2
