M sport suspension stiffness and ground clearance
03-19-2008, 01:06 AM | #1 |
Rep 1,399
For all of you that have this option or the entire M kit could you please let me know what ground clearance you have here:
http://img177.imageshack.us/img177/8947/96711009zk1.png is this M sport suspension harsh and rough? i'm still thinking if i should get it for my e90 335d (i still can modify the options until July); the thing is that although i just test drove a 2005 330i with this kind of suspension (code 704 in Europe) and it didn't seem that stiff, i still don't know if i should get it or not; i want a small drop on the stock suspension but i don't want it to be to stiff and difficult to drive because of the lower setup.... any thoughts from current owners will be greatly appreciated |
03-19-2008, 03:15 AM | #2 |
Rep 1,134
Drives: BMW G20 330e M Sport MY20
I find it ok, it can be very hard on poor surfaces at low speed.
For example when I hit a pothole it sounds as though I have damaged something! The electric bolsters do help to hold you in (if you are thin). The ride is firm like my previous car in a cabrio (without the scuttle shake). So when you are on rough road you must hold on to the steering. If the roads in Bucharest are like the UK then all of the above will apply. If they are like most of mainland western europe then you should be ok.
20 BMW G20 330e M Sport Portimão Blue/Cognac, Driver Pro, Tech,M+ lumbar, storage packs
Long gone -15 Peugeot 308 2.0HDi GT AUTO Magnetic Blue, 10 BMW F10 520D SE Xirallic Imperial blue/Cinnamon Brown, 06 E90 320si - Le Mans Blue - Totally standard specification (Scrapped RIP 12/08/2010), 00 Peugeot 306 2.0 SE Cabriolet, 94 Rover 214 SEi, 91 Fiat Uno 60S Mk2 |
03-19-2008, 03:22 AM | #3 |
Rep 8,811
Get it, its not particularly stiff. Looks great too!
03-19-2008, 03:45 AM | #4 | |
Rep 9,218
It's a relatively firm ride, although much less harsh than the sports suspension on the e46 model. On smooth roads it's pretty fluid and refined and I only feel it's an issue when riding over potholes or drain covers. In an average car you would hardly feel these, but with runflats and sports suspension they can be pretty crashy. Handling is superb though, with zero body roll and excellent balance. Personally I think it's an minimum requirement for a sporty BMW. |
03-19-2008, 05:18 AM | #5 |
Rep 34
It does look great - i'm really glad i went for it. On normal roads theres no problem.
As eveyone else has said its the potholes and drain covers that make quite a loud thump as you roll over them I dont know the exact drop though its not caused me a problem, i'm quite able to overhang the front on a kerb parked forwards |
03-19-2008, 05:42 AM | #6 |
Rep 13,043
Drives: BMW M340I G20
I had to take the wheels off my trolley jack to get it under mine (E92)
03-19-2008, 05:50 AM | #7 |
Rep 1,399
thanks for all your replys!
i really don't know what to do....i now it looks better and handles better but the roads here are very bad and i'm thinking that the stock hight setup could save the front bumper and side skirts from getting scratched; another idea would be to get the stock suspension and then upgrade the front and rear sways with M ones to reduce body roll when cornering but to keep the stock hight and comfort, what do you think about that? |
03-19-2008, 06:23 AM | #8 |
The Tarmac Terrorist
951
Rep 29,345
Drives: 997.2 GT3
the 335d comes with sport suspension regardless of model spec.
997.2 GT3
03-19-2008, 07:24 AM | #10 |
Right Responsible
58
Rep 1,646
Yep Carlos, It's only the E92 335d that gets the sport suspension as standard - and not the E90/1
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys. |
03-19-2008, 07:46 AM | #11 | |
Rep 9,218
I would have no hesitation at all in specifying the msport suspension. I wouldn't see the point of just fitting the sway bars. You may as well get the proper kit. |
03-19-2008, 08:24 AM | #12 |
Rep 5,984
The M-Sport suspension is a high quality shock made by Bilstein, it absorbs rough surfaces far better than the SE suspension, you would be mad not to have it it.
Why not buy a sport? The sport seats are the best I have had in any car, and are worth the extra alone, the SE seats are pretty poor imho. |
03-19-2008, 01:58 PM | #13 |
951
Rep 29,345
Drives: 997.2 GT3
997.2 GT3
03-19-2008, 02:14 PM | #14 |
Rep 1,399
why would i refer to e92?
check my sig....... btw, you can also get a lower and stiffer setup on the e92 if you order the M kit no matter if it is a 320d or a 335d.... |
03-19-2008, 02:59 PM | #16 |
951
Rep 29,345
Drives: 997.2 GT3
Nope, 335d coupe, se or msport same suspension.
997.2 GT3
03-19-2008, 03:10 PM | #17 |
Rep 1,399
03-19-2008, 03:23 PM | #18 |
951
Rep 29,345
Drives: 997.2 GT3
Thankyou I dont find it an issue, altho it is jarry over potholes with the 19". Ditched the runflats and its improved quite considerably Carlos
997.2 GT3
03-19-2008, 06:09 PM | #20 |
Rep 1,399
just drove my friend's 335d e92 M kitted and with 19" RFT and besides the fact that it is a beast!!!!!! the suspension felt acceptable even with 19" RFT so considering that my plan is to get 18" with non-RFT i think the choosing the M Sport Suspension would be a really good idea, am i right?
03-20-2008, 07:02 AM | #21 |
Rep 8,811
YES you are right!! Get the M-Sport suspension! You won't regret it!!
