Recommendations for brake pads on track days (from experience only!)
03-20-2008, 12:00 PM | #1 |
Whats that smell?
146
Rep 1,790
Im thinking this may be the wrong forum... Im not 100% sure....
From experience running a 335 at the track, can anyone recommend a good set of pads? The stockers are OK, but still lacking when backing down from 140+. Also, I know at this rate, they cant last much longer, so its a good time to start looking. My only criteria is that they dont eat up my rotors. Thanks |
03-20-2008, 01:09 PM | #2 |
Rep 4,838
Performance Friction Z-rated sounds like what you're looking for. It's a heavy duty street pad that bimmerworld recommends for track duty as well.
Bedding not required, lasts FOREVER (5 weekends and barely 1/4 wear), easy modulation, rotor-friendly. |
03-20-2008, 03:37 PM | #4 | |
Whats that smell?
146
Rep 1,790
Just the fronts? Does the back end play games? Do you have any more details about running these? |
03-20-2008, 05:21 PM | #6 |
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
Yummy
Car is now gone .... :-( |
03-20-2008, 05:59 PM | #8 |
Rep 4,380
No...strippers...not castro district....not your butt...sheesh....totally different. Mitchell Bros
03-20-2008, 07:01 PM | #9 |
Rep 4,838
03-25-2008, 08:47 PM | #11 |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
03-25-2008, 09:38 PM | #12 |
Rep 4,838
03-26-2008, 01:13 AM | #14 |
3893
Rep 54,605
Drives: F80 M3
That seems odd with only front brake pad change.
We have seen it when a more aggressive rear pads are used, but not the fronts. What is your rear toe setting at? Spring rates front and rear...damper settings? Aero aids? Heel-and-toe? |
03-26-2008, 01:32 AM | #15 |
Rep 4,380
I got this when using Pagid Oranges on the front with stock OEM brake pads in the rear on my last B5 S4. I had the Stoptech 332mm kit
03-26-2008, 09:06 AM | #16 | |
Rep 1,714
All suspension and body work was stock. And yes, I heel and toe. I believe the problem is screwed up brake biasing because of the major differential in pad coefficient of friction. |
03-26-2008, 02:41 PM | #17 |
Whats that smell?
146
Rep 1,790
shimshimhada, I dont see them on bimmerworld for an E92.
http://store.bimmerworld.com/shared/...t=products.asp |
03-26-2008, 03:49 PM | #18 |
MAUI BUILT
488
Rep 7,781
Drives: 2006 330i MT
I've tracked at Laguna with R4S pads with great results. R4's for sure will be great for track only use.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
03-26-2008, 06:42 PM | #19 | |
Rep 4,838
Send them an email or call them about them. If you can find out what code they are, you may be able to order them for cheap somewhere else like here: http://www.rotorsandpads.com/0548-10...s-0548-10.aspx |
03-26-2008, 06:42 PM | #20 |
Completely obsessed with detailing
299
Rep 15,442
Drives: E90 SG 330i, white Scion tC
i know you want a more hardcore set of brakes, but from the time i talked to hkj about his stock brakes, he said they were fine. they didn't fade that badly, and held up pretty well at laguna seca
so you may not HAVE to spend extra money on this |
03-26-2008, 06:53 PM | #21 |
Rep 4,380
stock brakes are not sufficient for me. I had fade and overheating and overflow of the brake fluid from the reservoir due to expansion / heat. I also had a squishy pedal.
03-26-2008, 07:11 PM | #22 | |
Whats that smell?
146
Rep 1,790
