E92 335i rear brakepad sensor
06-30-2016, 05:29 AM | #1 |
Rep 256
Drives: 335i M3 Look
Hi
is it normal to have brakepad wear sensors on both sides in the rear? all the DIYs state its only on one side. thx
E92 335i 2007 Crimson Red 6MT M3 look-ER CP-TIAL BOV-MMP hotside intakes -DP-DeCAT-JB4-CDV-Trebila custom map, Meth, M3aybar(front)-Mtech SMFW,550I clutch, 5.5" IC,
06-30-2016, 06:04 AM | #2 |
6 of Diamonds (ret)
82
Rep 566
Yes typically they are one per axle. Depending on what you are looking at(just wires) you may be mistaking it for a wheel reluctor (wheel speed sensor).These tell the ECU's how fast each wheel is turning.
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
06-30-2016, 06:20 AM | #3 |
Rep 256
well I have done diagnostics, and had two rear brake pad errors(CD-ID 71), changed brakepads and sensor one side, reset errors and did another test, now I only have one error...
07-09-2016, 06:54 AM | #5 |
Rep 256
well changed the rear one, fault gone. Looked to the other side, ah it was the ABS wire which fooled med. went up front, yanked out the sensor, crossed the wires, reset errors, annnd...dang!..still error on the front..
everywhere I have looked it says to cross the wires to fool the ecu...(or change sensor obviusly)... but why does it still say error ?
07-09-2016, 11:38 AM | #7 |
Rep 14,829
07-09-2016, 12:37 PM | #8 |
Rep 256
Yes I will eventually.. just had to quick fix it..and so I was surprised it didnīt work with shorting the sensor wires ... :/ maybe someone knew why...
on a side note, there was quite a bit of brakepad material left on the pads when the sensor was worn out... could have gone way longer..
07-09-2016, 06:37 PM | #9 |
Rep 824
Yeah my car only has 18k miles sensor showing need rear pads-
In the past had this happen for front brakes and was bad sensor - They charged me 50 bucks even with my warranty bc of the minimum fee. Is the sensor easy to change ? |
07-10-2016, 04:37 PM | #10 |
Rep 256
yes its quite easy .. if you can change a tire you can do it
07-13-2016, 01:46 PM | #11 |
Rep 256
just a little update, today I flashed the lastest MHD backend and the error went away
