E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Dorman eccentric shaft sensor
Reply
      07-01-2016, 01:54 PM   #1
F30RiK
Drives: 13' 335 xdrive M-sport 6 Speed
I need an eccentric shaft sensor and here in Canada I can't get a good price for the original siemens VDO (around 450$ here).
On rockauto I can get a dorman one for 250$ CAD shipped.. (almost half price).
I checked on their website and its seems fine..
Original Engine Variable Timing Eccentric Shaft Sensors typically fail due to spot welds in the original design, which allows oil to seep into the unit; leading to electronic failure. Dorman's OE Fix solution offers a new design featuring a new stronger ultrasonic weld to prevent oil from contaminating internal electronics.
Direct replacement for popular BMW applications
Re-engineered by Dorman to address failure modes found in the original design
Replacement protects against potential engine damage
This part has undergone vehicle try-on and vehicle simulator testing to meet product standards and quality
http://www.dormanproducts.com/p-7734...sor&origin=YMM
What you guys think?
      07-01-2016, 02:07 PM   #2
brewnami
Drives: 2009 BMW 335i M Sport Coupe
Is there any warranty on that part? Not sure if you're going to DIY this, but it's a pretty time consuming job and most people do the VCG at the same time. I mean, if there's a decent warranty and you're doing the work yourself, I'm sure it will be fine. It's not like the OEM one is all that good. My wife's failed on her 2011 E90 with like 45K miles on it.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
      07-01-2016, 02:07 PM   #3
7786
Drives: 2011 535xi
I don't have any experience with their ESS but I did install two Dorman vanos solenoids a few months ago for $35 each. They've been working great for me, car runs much smoother and two solenoid errors are gone.
      07-01-2016, 02:12 PM   #4
F30RiK
I'll do the job myself, I have another car so I can take my time doing the job. I already ordered Valve covert gasket and bolts, Eccentric shaft gasket and valvetronic gasket, intake gasket and the vent hose. I'll replace my starter in the same time (starter and new bolt are already here).
Im only missing the eccentric shaft sensor now.. and I don't feel like paying 450$ for it lol
I'll also take a look at both disa valve (hope they are fine lol)
      07-01-2016, 02:46 PM   #5
Willsbma
Willsbma's Avatar
77
Drives: 07 328xi
How did they look compared to bmw?
      07-01-2016, 10:21 PM   #6
bmw325i
Drives: 2006 BMW 325i
I would go for it. The original part is a bad design and the Dorman part seems like an upgrade based on the description.
      07-02-2016, 01:25 PM   #7
F30RiK
Ok so I ordered it. I'll let you know guys but im pretty sure the part will be fine.
      03-08-2022, 12:07 PM   #8
vancity67
Drives: 2011 328i xdrive
hi, i am looking at this as well.. did it work well? i have a 2011 328xi.
Reply
e90post
