2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning m235i: rough costs of head gasket, cylinder head, and engine replacement?
      08-01-2016, 07:12 PM   #1
DfVgyCjmFQnu
Drives: 2015 m235i Auto Coupe
I have a 2015 m235i RWD Coupe
Do any of you have an idea of the rough costs of the following repairs?
1. Cost for head gasket replacement
2. Cost for cylinder head replacement
3. Cost for complete engine replacement
Thanks in advance.
      08-01-2016, 07:51 PM   #2
APX2APX
Drives: 2016 M235iX
Thanks in advance.
You need to supply your reason before any answers... LOL
What happened?
      08-01-2016, 07:53 PM   #3
Beartato
Beartato's Avatar
882
Drives: M235i
More than you can afford, pal.
EEBreh122.50
      08-01-2016, 08:44 PM   #4
pz619
Drives: F87 M2C 6MT, Tesla 3
Thanks in advance.
Well, color me interested... What happened.
$15.6k for the engine replacement (getbmwparts.com). That doesn't include labor. Msrp is over 19k.
      08-01-2016, 09:31 PM   #5
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
Also curious what happened, how'd you blow the motor?
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      08-02-2016, 12:54 AM   #6
DfVgyCjmFQnu
BMW dealer found coolant in my cylinders. They are saying the fix is going to be one of the above three options. The engine runs fine (for now) but was burning through 1-2 liters of coolant per week recenty.
      08-02-2016, 02:07 AM   #7
pz619
Warranty still applicable? Assuming you aren't stock if they aren't picking up the tab?
      08-02-2016, 09:20 PM   #8
BentZero
BentZero's Avatar
Drives: 6MT Mineral White M235i
Any reason for it not to be covered?
I rev-match from neutral to first
6MT Mineral White on black M235i coupe
Build thread
      08-02-2016, 09:49 PM   #9
amw896
amw896's Avatar
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
damn! I'm sure they will sort you out. Heavily modded?
      08-03-2016, 12:32 AM   #10
DfVgyCjmFQnu
Not heavily, just an ECU tune and a catless downpipe. I don't believe these two mods alone would destroy an engine. I think there was a defect at the factory as I only have 15,000 miles on the car.
amw896582.50
      08-03-2016, 12:45 AM   #11
Luminous
Luminous's Avatar
743
Sorry to hear about this, I agree it sounds like a factory defect vs a tune related issue. I remember you mentioned having to top off coolant in a previous thread which is very unusual. I really hope BMW covers this for you, pls keep us posted!
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      08-03-2016, 01:53 PM   #12
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
yes, please keep us posted.
Did you flash the ecu back to stock? Remove the DP?
      08-03-2016, 05:42 PM   #13
APX2APX
Drives: 2016 M235iX
Crack a head is possible if engine isn't warmed up yet and with aggressive throttle.. Even more so with a tune.
If you want to play... You have to pay.
Sucks, but it's true. Hopefully they will help you somehow.
I'm personally staying away from any engine/drivetrain mods.
      08-03-2016, 07:31 PM   #14
Drpoomanchu
Drpoomanchu's Avatar
Drives: AW M235i Man FBO
Were you missfiring? Throw any codes..? Coolant in the oil..?
Without pulling the head and checking your plugs it will be hard to know your exact situation. I would think a cracked head or block is not likely. Probably head gasket failure. What i would be more worried about is a tech finding a HG failure to be the cause then just replacing, checking leak down, and compression then calling it a day. With the coolant seepage depending on if coolant mixed into your oil it could have diluted, depending on longevity and severity, and cause premature rod bearing failure Etc. A lean A/F mixture or detonation could have caused your problem. I hope BMW takes care of you and wish u the best of luck
      08-03-2016, 07:42 PM   #15
DfVgyCjmFQnu
BMW is denying any repair under warranty as they found the ECU had been tampered with. So here's hoping it is only a gasket that needs repair.
I was not throwing any codes, engine was running fine, just needing to add coolant every week and 1L oil every few thousand miles. I did not see any coolant in the oil though I did only visually inspected it and did not sample it much.
      08-03-2016, 08:07 PM   #16
xantdieselx
Kingslayer
xantdieselx's Avatar
Drives: 23' M3 Base
Sucks to hear that. Hoping for the best for you.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
      08-03-2016, 10:28 PM   #17
Luminous
Luminous's Avatar
743
Sorry to hear that. For future reference, you should have the ecu flashed back to stock before any warranty claims.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      08-03-2016, 10:36 PM   #18
Pparana
Drives: 2015 m235i
No surprise there on warranty, doubt it is just the gasket at that volume. Does the coolant look contaminated? Prob need to do the heads. I would pull the mods and trade it in somewhere.
      08-03-2016, 10:45 PM   #19
BentZero
BentZero's Avatar
I'd feel too bad if someone eventually bought it thinking that it's fine.
      08-03-2016, 11:02 PM   #20
Taunto
Car Enthusiast
Taunto's Avatar
Drives: 2016 BMW M235 X-drive
-Believe it or not......
But we have done some fair amount of Cylinder Head gaskets on the N55 Engines here at the shop over the past year or so.
98% of the failures are just the gaskets.
It is not an cheap fix.
Don't be surprised if they Quote you new Vanos control units as they will most likely need to be replaced during the repair.
If the vehicle is at the dealer that you bought the car from... and even if you have been a customer in the past, I would try to talk your way into getting the dealer to GOOD WILL some of it for u.
Each deal is different but ive seen some where its 70/30 so customer pays 70 and dealer pays 30, Or customer aggrees to buy all the parts at full cost and the shop covers the labour.
Im surprised that they found that dme had been tampered with? Did they say in person or Tech notes that they made a PUMA Case for the cause? Was there a No ENCODING fault found when they scanned faults.
If you havent told them that it's tuned/flashed, id ask for proof from either them and or Puma showing that it has been tampered with.
Downpipe and or Charge pipes are not going to cause a Headgasket to fail.
I know it's not what you wanted to hear, but it does give you some viable options.
Hope some of this helps
      08-03-2016, 11:03 PM   #21
Taunto
Car Enthusiast
Taunto's Avatar
Sorry just realized your from USA... so instead of a PUMA case..ask for proof from either the shop and or Tech support(sort of the same thing just different in the USA thats all)
      08-03-2016, 11:39 PM   #22
Luminous
Luminous's Avatar
743
Great info, thx! What would be some early symptoms of a failed cylinder head gasket? Any other N55 specific issues you've encountered?
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
2addicts
