30ff Limp Mode Unsolvable?
08-11-2016, 05:34 PM | #1 |
Rep 59
I've been chasing this 30ff underboost code since I've taken ownership of an '07 335xi at bone stock form. Car drives fine until you start building boost and hit 4000 rpm's, then you get the *ding* engine malfunction reduced power warming that corresponds to a 30ff turbo pressure too low code. I have added a MHD stage 1 + fmic tune with CP, DV's, FMIC, and DCI's and still get the dreaded 30ff. I had my Indy do a smoke test and he claimed that he adjusted both WG actuators, but to no avail. Car has WG chatter at cold startup for about 30 seconds, then goes away. It pulls like a freight train until I hit 4,000 rpm, then goes into limp mode. Any ideas? I'm at my wits end here...
What I've done: All new silicon vacuum lines (WG actuators-boost solenoids-canisters-oil filter housing...) Both WG actuators tested to fully close at 5.9hg and hold vacuum Tested vacuum canisters and replaced one with split nipple Replaced stock CP with a BMS charge pipe and Forge DV valves (yellow springs) New Pierburg boost solenoids Helix FMIC BMS DCI Boost leak tested and heard air at lower FMIC connection, fixed the clamp, still 30ff.... |
08-11-2016, 05:43 PM | #3 | |
Rep 59
08-11-2016, 07:03 PM | #4 |
Rep 252
The rear one can come loose. Easy way is to try lever it back on from the top of engine with something.
The rear cone moving around is what causes the rear inlet to come loose so recommend you tether it to the manifold. |
08-13-2016, 02:25 PM | #6 |
Rep 59
Thanks guys, I just removed all of the undertrays and still could not figure out how to access the rear turbo inlet to check if it was seated...but checked my hot and cold side intercooler connections and found no indications of leaking. I pressurized the inlets and confirmed no leaks at the intercooler. However, I found a substantial leak at the oil filler cap?! Any harm in pressurizing my crankcase (12-15psi) like this? I didn't feel like taking the cowl off to block the PCV heater hose. Could this be my 30ff boost leak lol?
08-13-2016, 02:29 PM | #7 |
Rep 1,497
Look where the downpipes are, right above the downpipes you should be able to see the rear turbo. If not than u might have to remove the downpipe to properly access the connection. There is a gasket that sits on the turbo inlet and the plastic tube covers it. Over time this slides off.
08-13-2016, 04:35 PM | #8 |
Rep 59
Ok, I followed your instructions and located the rear inlet. It is completely on the turbo, which I verified by leveraging a long screwdriver on it hoping to slide it on further. I then removed the PCV hose that attached to the rear inlet and capped it off and tried another boost leak test. Nothing audible...? I also used my Mityvac again to test all of the vacuum lines running to the canisters across the manifold and they hold vacuum fine. Tested both wastegate actuators and found the rear rod is fully closed by 200 bar of vacuum and the front actuator is fully closed by 225-250 bar. Both actuators move freely without binding and hold vacuum. Can't be the solenoids because they were just replaced. Man, I'm stumped at this point! Sooo close to just dropping the subframe and pulling the turbos...
08-15-2016, 02:48 PM | #10 | |
Rep 59
I just rebuilt a set of cores with the TurboLab guy's rebuild kit and wastegate flapper fix and I'm so close to just biting the bullet to install these. I'd hate to go to that much effort only to find out it was something simple haha... Last edited by jakeadake; 08-15-2016 at 03:01 PM.. |
08-15-2016, 03:23 PM | #11 | |
Rep 9,209
I have seen in with codes for misfires, codes for fuel pressure and vanos solenoids and when those issues were resolved the 30ff didn't reappeared. I'm not sure how if works but is somehow link with engine going into limp mode. I would say address P0171 and P0174 first especially if the info on when they occur, like time and rpms is identical or before the 30ff Also, if you can post a log. |
08-15-2016, 04:12 PM | #12 | |
Rep 252
08-15-2016, 04:52 PM | #13 | ||
Rep 59
Also to clarify the previous post, the P0171 and P0174 seemed to go away after I cleaned the TMAP sensor. It was a bit dirty. After resetting ECU/adaptations I'm continuously only throwing the 30ff code. Will see if I can get a log through the MHD when I'm back in town with the car. |
08-15-2016, 05:49 PM | #14 |
Rep 116
Very similar circumstances to my 335xi. I smoke tested it and found no leaks whatsoever. I decided to manually adjust my rear turbo wastegate closed a little more and voila, problem fixed. The actuator is worn and old and after tightening the clevis on the rear turbo, problem gone. Couldn't get the front one adjusted, even when removing downpipes so I said F it. Either way, problem gone.
jakeadake32.00 |
08-15-2016, 08:14 PM | #15 | |
Rep 59
I asked my Indy what the trick was to adjust the front actuator and he said "a pick and a magnet". Doesn't sound right to me since it takes a stubby 10mm for the locknut and a tiny 4mm to turn the rod...I'm actually doubting he smoked it and adjusted the rear at this point, so I'm going to go through those again... |
08-23-2016, 10:14 AM | #17 | |
Rep 9,209
I'm affiliated with a shop in Smithsville, NC. LEt me know. I can refer you there. |
08-23-2016, 01:45 PM | #18 | |
Rep 116
the front turbo needs a pick for sure. I pulled the clevis and spun it til it stopped. worked fine. the front I couldn't do but if I did, the pick method is the trick. |
jakeadake32.00 |
08-23-2016, 02:02 PM | #19 | |
Rep 59
Thanks for the insight, that's a creative approach. When I asked about removing the thermostat, waterpump, fan, intercooler to get to the front he claimed they did none of that so that seemed like a hell of a feat. Right now I'm away from the car until the weekend, but I have it on jackstands ready to start pulling the stock DP's. As an incentive I bought some VRSF catless DP's to take their place as well as new actuators. My plan of action for the weekend is to install new actuators and readjust/ check the play on the WG arms. If nothing is binding I'm hoping this will cure my 30ff. If they're shot, well I'll bow to the turbo gods and pray upon my rebuilt cores...but that'll take me a couple weekends. I'll keep the thread updated as I make progress! This is my first BMW, direct injection/twin turbo inline 6 for that matter. I traded a built Cummins turbo diesel for the car, so some familiarity with a turbo 6 cyl. platform. Last edited by jakeadake; 08-23-2016 at 02:08 PM.. |
08-23-2016, 02:11 PM | #20 | |
Rep 9,209
Why don't you try another tune? Might be your tune. H ere is the shop info: Import Car Service 36 E Edgerton St, Unit C, Smithfield, NC 27577 (919) 205-1133 I was there two weeks ago. Probably Justin will answer but ask for Alec, the owner. |
10-01-2016, 04:54 PM | #21 |
bOrN To DiE
413
Rep 1,738
10-01-2016, 05:19 PM | #22 |
Rep 946
Tl;dr
But every 30FF has a solution. If you've replaced and verified the vacuum side and you've verified no boost leaks are present then you're down to either bad wastegate solenoids, worn actuators, or failing turbos. My money would be on worn wastegates. Sometimes the wastegates wear so that they will be okay most of the time, but tend to bind when closing and fail to fully seat. There is a video on YouTube demonstrating this. |
