08-12-2016, 03:48 PM | #1 |
Rep 665
What Sway Bars Are Available For M2?
Hi I am looking to upgrade the suspension with KW V3 and also trying to find reputable brands for the sway bars.
Does anyone know what's available right now? |
08-13-2016, 02:32 AM | #3 | |
Rep 665
08-13-2016, 02:48 AM | #4 |
Rep 2,148
Drives: F87 M2 BSM MT
Are you having a lot of body roll? Have you tested on the track as yet? I was thinking about getting coils but based on all the track reviews I didn't think sways would be needed. Let me know if this is another mod I need to add to the list.
08-13-2016, 09:07 PM | #5 | |
Rep 665
You should just try it and maybe you'll have a different aspect with regards to the need for sway bars. |
08-22-2016, 07:27 AM | #8 |
Rep 2,588
Has anyone run their M2 on a track hard/fast with Michelin SC2s or similar. That will certainly tell you if you need to upgrade the sway bars and stock suspension?
08-22-2016, 01:54 PM | #10 |
BimmerPost Supporting Vendor
3885
Rep 54,494
Drives: F80 M3
You should try to tune with springs before you get bars. Use bars to balance the handling not use them as a main suspension tuning tool.
09-21-2016, 12:06 AM | #11 |
Rep 220
Has anyone changed sway bars on their M2's yet? I am curious to know the difference in handling / feel. The Dinan ones look the goods.
MY21 BMW M4 Competition (Ordered)
MY19 BMW X5 40i M Sport MY15 Harley-Davidson V-ROD Night Rod Special |
09-21-2016, 02:15 AM | #12 |
Rep 2,148
I've been on the track, car does not feel like it needs any upgraded swaybars. Car feels a lot lighter than it actually is and very balanced. Brake pads do need to be upgraded to track pads as the stock pads gets smoking hot very quickly.
09-21-2016, 02:31 AM | #13 |
Rep 220
OK thanks for the insight. I've ordered the H & R springs and 10MM spacers for all four wheels so this should improve a little over stock also.
I'm surprised and disappointed by what I'm hearing about the brakes (and there has been numerous reports on this) as I had the M Performance brakes (the upgraded version / red) on my M135i and they performed really well at the track, no fade at all - I would have thought the M2 would be better than those!
09-21-2016, 02:40 AM | #14 | |
Rep 2,148
09-21-2016, 03:22 AM | #15 |
Rep 220
Interesting. You'd think a full blown M car would have those pads standard..!
09-21-2016, 07:36 AM | #16 | |
Rep 2,148
ddnmkun153.50 |
12-28-2016, 12:59 PM | #17 |
3885
Rep 54,494
Drives: F80 M3
02-28-2018, 05:47 PM | #18 |
'17 M2 Mineral Grey
Rep 15
Anyone changed rear swaybar?
I have a bit of steady-state understeer in my M2 after installing slightly wider P4S tires (268/285) on stock rims. Previously, it was slip and slide power-oversteer fun. But with the wider P4S's in the rear, the front tends to run at a much greater slip angle than the rear. And the power can be easily put down.
Picked up a Dinan rear bar that should allow a slight spring rate increase in the rear that should allow tuning this out (hopefully to full neutral where both front and rears slip at similar angles in steady-state). However... there's a local mechanic down the street from where I work, and he indicated the BMW manual calls for dropping the rear sub frame to install this(!). 8 hours. I figured it would be an easy job that wouldn't cost a lot to keep me off my garage floor. So... anyone have experience with replacing the rear sway? And does the sub frame really need to be unbolted/realigned?? |
Acexxon639.00 |
03-01-2018, 06:13 AM | #19 | |
Rep 665
03-03-2018, 08:07 PM | #20 |
587
Rep 898
The M2 uses M4 Vert front sways and M3 CS rear sways so...
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
horsepower_and_hounds1837.00 |
03-05-2018, 06:20 AM | #21 |
Rep 4,525
Front sway bar OE part no for M2 is 31352284762 - same as non CP M4 vert
Rear sway bar OE part no for M2 is 33557853266 - same as non CP M4, M4 CS and M4 GTS Perhaps a logical upgrade could be to swap to OE front sway bar part no 31352284760 - from non CP M4, M4 CS and M4 GTS - to match the rear ???
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
03-05-2018, 09:23 PM | #22 | |
587
Rep 898
Personally I'm not a fan of using sway bars to control body roll, as its just a cheap fix. Doing so compromises what the shock actually does.
