help obd emissions test
08-15-2016, 01:47 PM | #1 |
Rep 381
Hello I wanetd to ask you for some help.
I live in mexico city and currently have a 2012 1m. I have the following mods: Cobb Fmic Cobb charge pipe Cobb catted downpipes Cobb accesport V3 with custome PTF stage 2 tune Maddad midpipes Akra rear section In the recent months the city has now established emission inspections via OBD port. I have read several therads on the n54 emissions tests etc and how to pass them but im not 100% clear and thus wanted to ask for some help or pointers. To try and get ready for the inspection so far I have scanned my car with the cobb accesport (had a couple of codes and cleared them), then I proceded to buy an autozone obd car doctor device to scan the car. To my surprise it threw this two codes . P0420 P0430, I have read both this codes are associated with catless donpipes. (mine are catted) . To be sure I am doing things correct. I now need to flash my car back to stock tune, then erase all codes and proced to record a drive cycle. myq uestiosn are: 1.-How do I knowo the drive cycle is completed? 2.-The codes I have now P0420 P0430 can be due to the car currently not having recorded the drive cycle? or with the stock tune they should go away? 3.-Do I need to buy and install a DP fix even though my downpieps are catted? Again thank you for your help regards diego garcia |
08-15-2016, 05:36 PM | #3 |
Rep 1,130
There is a readiness test that will be marked as completed that is read over the obd2 port. Your aftermarket cobb catted pipes probably aren't effective enough to allow that test to complete successful hence the power train codes you listed.
Even if you disable the codes the emission check will never complete (at least in my experience). Probably will need to put the stock cats back on or look for another aftermarket option that is more effective. |
