Spark Plugs
08-15-2016, 07:02 PM | #1 |
Rep 281
Spark Plugs
What kind of spark plugs do you guys use on your car?
Is the NGK IRIDIUM IX good spark plugs to get? Or should I stick with the bosh OEM plugs? What do you guys gap them at? I'm pushing 14PSI if that helps |
08-15-2016, 07:26 PM | #2 |
Rep 75
If you're running boost above 10psi it is recommended to ditch spark plugs and
replace it with good quality glow plugs... Go away Bryan!!!! BTW Last edited by Jake335is; 08-15-2016 at 07:51 PM.. |
08-15-2016, 07:27 PM | #3 | |
Rep 281
08-15-2016, 08:24 PM | #5 |
Rep 386
Drives: 08 535xi 11 328xi
I'm running 13 psi and I'm running oem plugs with no issues. Most people that are running higher boost are sticking with oem plugs, they work fine. You will just have to change them more often, I think it is like every 15k miles when running a tune. Don't get them from bmw, they are over $20 a piece I think, I got mine from amazon.
08-15-2016, 10:40 PM | #6 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
08-15-2016, 10:41 PM | #7 | |
Rep 281
08-18-2016, 02:41 PM | #8 | |
Rep 96
Gizm0427.50 |
08-18-2016, 02:53 PM | #9 |
Rep 707
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I run these, OEM part number and running MHD stage 2. Great price and work perfectly. Edit: Accidentally posted the spark plugs from my Z3M. Sorry Last edited by Mr. Tasty; 08-18-2016 at 04:32 PM.. |
08-18-2016, 03:00 PM | #10 | |
Rep 281
08-18-2016, 03:29 PM | #11 |
Rep 554
Drives: 2013 335is E93 6MT
These are the ones you want:
https://www.amazon.com/gp/product/B00NNYLBS0/ The other Boschs are for the E36, I believe, but whatever. They're all available for around $45 or so on Amazon, though I'm sure you can pay more for them elsewhere. The NGKs go for ~50% more. I'm running 20-21 PSI boost on an E60 tune, and I'm currently on the OEM plugs the dealer installed ~8K miles ago.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
08-18-2016, 03:41 PM | #13 | |
Rep 2,136
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch |
08-18-2016, 04:28 PM | #14 |
Rep 707
they are the OEM spark plugs down to the Realoem Partnumber.
Edit: I apologize, those were for my Z3M https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 These are for the 335i |
08-18-2016, 11:20 PM | #16 |
Rep 161
I have used OEM (Bosch), Bosch (aftermarket) and NGK. NGK were good but died quicker, maybe 15k. Bosch I have been able to get 18-20k. My car is FBO running 18-20 psi on stock turbos. Although lately the price has been coming down so much on the Bosch that I am beginning to wonder if any of them are counterfeit. Two years ago I could not find a set of 6 below $70, now they are under $50. But so far, no problems with any I have purchased.
v12 Flash, Turbonator, The Tornado, FD47 power booster, Turbo sound whistler, Nitrogen filled tires, The Ghost Pro, Joe Gibbs BR30, AFE DAS, Nut blast
08-18-2016, 11:33 PM | #17 | |
Rep 281
08-19-2016, 05:16 AM | #18 |
Rep 554
Life is good! Now that we're done with plugs, let's all go back and argue about oil. LiquiMoly FTW!
04gto106.50 |
08-20-2016, 05:31 AM | #19 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
You should replace the plugs if your close to the 45k interval and coils especially if your over 100k on the coils, when thinking about running a tune.
A tune will eat plugs more often. Depending on psi, you maybe are changing them every 30k vs every 45k. Oil would obviously have to be changed more often too. I'd consider a 5w-40 weight vs a 5w-30 as well., |
