DIY Experiment - Dual Cone Filters in Custom Colors
08-15-2016, 10:59 PM | #1 |
Rep 1,372
A few weeks ago, I was reading through a thread looking at some beautiful engine bays when I was inspired to try and clean my own up a bit. My BMS dual cone filters were looking a bit dirty these days and ever since installing my amber halos, I'd thought of doing some type of amber/orange filters to break up the all black.
Here are the supplies I started with:
I used a stainless steel sink, so I wouldn't have to worry about making a permanent mess. I also watched the video published by RIT on how to use their liquid dye, and they suggest adding a bit of salt in the hot water when dying cotton and similar materials. After dissolving the salt in hot water, add a bit of dishwashing liquid to the mix. Add the liquid dye. I used about half the bottle and then stirred everything up. Slowly submerge the filters into the water and dye mixture until they're sitting on the bottom. Do the same for the second. Keep checking in on the color of the filters and remove once you get to a desired shade. After letting all of the dye/water mixture drip off as possible, I transferred the two filters to the other side of the sink. To ensure no staining, and to stay on good terms with my girlfriend, I gave the sink a good scrubbing with a soap pad. Rinse thoroughly. This may take a while before you see the bleeding colors stop dripping. Eventually the water will run clear though. I then added a bit of dishwashing liquid to the sink, refilled with fresh water, and gave the filters a good cleaning, just as I would with a dirty set. Place on a towel you don't care about and let dry. I sat mine outside on a hot summer day to speed up the process. From there I applied the Green Filter orange oil so I wouldn't compromise the intended color of the filters. Add the anodized black aluminum couplers and they're ready to install. And the final product with black DME cover and brake fluid reservoir: I can't see how dying the filters, cleaning them thoroughly, and re-oiling them would have any negative effects. RIT also comes in about every color imaginable, so the possibilities are endless.
08-16-2016, 12:15 AM | #2 |
Rep 946
How many hours did it take to make your filters look just like the readily available red filters?
Cool idea though. |
08-16-2016, 09:58 AM | #3 | |
Rep 1,372
And to be honest, only about a half hour of actual work involved if that. |
08-16-2016, 12:34 PM | #6 |
Rep 922
08-16-2016, 12:54 PM | #7 |
Rep 1,735
OP not a bad idea
|instagram@underground6t9| |
08-16-2016, 01:17 PM | #8 | |
Rep 554
Drives: 2013 335is E93 6MT
Source: young daughter with electric lime green fetish
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
davidwarren188.00 |
08-19-2016, 04:24 AM | #9 |
Jedi samurai ninja turtle
621
Rep 3,021
Drives: X3 M40i 2018
Good effort OP
08-19-2016, 01:23 PM | #10 |
Rep 532
09-02-2016, 11:39 AM | #11 |
Rep 1,372
UPDATE: Cleaned up the engine bay further, tucked wires away, added an RB External PVC and high/low catch cans. About 1,000 miles on these filters so far and no issues, no color loss.
