E85 is only 54% ethanol
09-09-2016, 01:45 AM | #1 |
Rep 159
Hello forum members, I have been getting e85 from this Chevron station and today I see they put a sticker that says 54% ethanol. I have been and still running e40 with MHD and I dont know if I should still mix the same (4.5gal of e85 to 3.5gal of 91oct) for e40 or am I gonna have to recalculate the mix? The clerk told me this is statewide for e85. Thanks for your help.
09-09-2016, 06:37 AM | #5 | |
Rep 272
FBO , MHD , tuned
09-09-2016, 09:02 AM | #6 |
Rep 154
I just found this out as well. Got set up for a full e85 tune and ended up with e53. I have a Bluetooth ethanol analyzer. Had to drive around until I emptied the tank and tried a few pumps. Best I could find around me was e73.
TrollToll654.00 |
09-09-2016, 09:33 AM | #8 |
Rep 124
I don't understand why the norm for this platform isn't to run an ethanol fuel sensor. I realize that running a full flex-tune is likely not feasible with the stock ECU (although that would be amazing) but being able to check your ethanol content with your phone and then flash a custom (interpolated) map designed exactly for your current tank of fuel would take a lot of the guesswork out of ethanol tunes.
09-09-2016, 10:54 AM | #10 |
Rep 2,084
Really?! This must be new.
I haven't gotten E85 for a few months but the only sticker it has said "No less than 70% ethanol" or something like that. I get it at a 76 station. It's typically been around 80% ethanol. I have fuel-its sensor kit and bluetooth analyzer.
2013 135is DCT Carbon Black Metallic |
09-09-2016, 11:11 AM | #11 |
Clean is the new cool, keep it that way.
808
Rep 1,685
Here locally from Valero it can be in the E50's to E70's, I have never seen it hit E80+. I don't run it in my 335i (yet) but I do run it in my Turbo RX-8 and when it's off, it screws with my tune big time. And with a Cobb tune it is not so easy to change the tune so I have to play with the mix using gas cans. Luckily I don't drive it much so once I get the tank right it lasts for a while. I have VP fuels locally, I am considering getting it from them.
09-09-2016, 11:58 AM | #12 | |
Rep 723
2007 335i E92 MT | MFactory LSD | Diff Brace | MHD/Wedge Tuned| BL Coils | Stg2 lpfp BoostConcepts | VRSF DPs | VRSF 7" HD FMIC | DCI | VRSF CP | BMW SSK | Billstein PSS Coilovers | M3 Control Arms | Whiteline Rear SF Inserts | SS brake lines | Z4 35is Rotors | Hawk 5.0 pads | M219s + PSS | PE Mod -SOLD
2016 M4 F82 MT |
09-09-2016, 12:03 PM | #13 |
Rep 554
Drives: 2013 335is E93 6MT
I have Steve's kit but I've never tried it. I use U Gas, which is from Urbieta Oil, a local company that has most of the E85 stations in the Miami area. I just upped the percentage a bit in the winter months, being in the southerly zone where the ethanol content doesn't drop all that much then, and have simply used the standard ratio of 2 gallons of E85 to a gallon of 93 octane for achieving E60 the rest of the time. Guess I'll have to bust out the kit.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
09-09-2016, 03:09 PM | #14 |
Rep 370
Here in Illinois I get mine at the Speedway stations... I run it 100% with a custom Wedge tune, and the last 5 fill-ups its been right around E80 according to my Fuel-it sensor/ bluetooth analyzer
2009 Z4 35i 6mt, SpeedTech 6266 Gen2 turbo kit, Tial WG, VRSF 7.5 race IC, ER charge pipe, Tial BOV, Radium Fuel cell w/ surge tank and twin Walbro 525 pumps, Radium FPR and return line, Bluetooth ethanol sensor, Phoenix intake manifold w/PI, JB4 tuner, PR coil packs, Custom oil cooler, ECS Radiator, Spec 3+clutch, Mfactory flywheel, single 3.5" into dual 3" exhaust, H&R springs, 19" TSW wheels, 235/19 & 275/19 RE11 tires
09-09-2016, 04:50 PM | #15 |
808
Rep 1,685
09-10-2016, 07:43 PM | #17 | |
Rep 510
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
09-11-2016, 07:26 AM | #18 |
Rep 946
09-11-2016, 02:20 PM | #19 | |
Rep 554
I was originally thinking that if this makes its way to Florida, I should get Steve's ethanol sensor/fuel line installed. But if pump ethanol is going to vary at any given time from E50 to E85, what good is that going to do if, say, you run an E60 tune like I do, you fill up with 10 gallons of what you think is E85 and 5 gallons of 93 octane to get the E60 mix, and find out the pump really had E50 because the sensor shows you're running E37? The only option I see is testing with the little plastic cylinder with water before filling up. Not sure of the logistics of doing that every time (carrying around a small gas can into which you can pump a splash of ethanol, and a bottle of water?).
BeastMode335i1132.00 |
09-11-2016, 06:05 PM | #20 |
Rep 1,473
You guys had to know that this was coming. No one is using E85 for it's original intention. I am sure that the government knows that the only consumers using E85 are those people seeking higher octane for performance reasons and not for it's cleanliness.
It won't be long until E85 is not available anywhere. In my state (NC) you can hardly find the stuff. I think that there might be a few stations in the entire state and none in Charlotte. |
terryd5150507.00 |
