More METH???
09-12-2016, 10:27 AM | #1 |
Rep 804
More METH???
i'm FBO plus inlets running all out stock turbo e60 tune with AEM meth kit (1000cc nozzle) with 60/40 meth/water (measured by weight). controller is set to start spraying at 7.5psi and fully spraying at 18psi
has a slight hiccup mid pull but no codes thrown...... question is do i need more meth ? when i ran a 50/50 mix, there was no misfire and hpfp looked a little stronger HPFP seems to dip pretty low track day is friday night and need to get this sorted out so i can finally get well into the 11's with the drag radials/meth etc http://www.datazap.me/u/msport335/e6...og=0&data=4-22
E90 LCI M-sport/ 6AT/ LSD/ FBO+
09-12-2016, 10:42 AM | #2 |
3442
Rep 79,211
I think you posted before about your nozzle size, which I mentioned was too big.
If you are running 60% water that would also be a problem. IT's too much water and you could be quenching. If you don't want to run a high concentration of meth then I'd recommend going to a smaller nozzle. Other solution would be more meth concentration or setting you controller not to do full spray, so only 50% throughout. With a proper nozzle, you can run 100% spray at 8PSI without issue even at 50/50 mix. Your 1000CC nozzle is nearly 16 GPH, which is HUGE! You need 12 GPH max, especially with that much water, AKA 750CC. More is not necessarily better, especially with water. The idea with Meth/water is to spray the least amount to achieve the results necessary. Too much is not only wasteful but can also lead to quenching. Hope this helps. Last edited by Jeff@TopGearSolutions; 09-12-2016 at 10:48 AM.. |
Amack101.00 |
09-12-2016, 10:47 AM | #3 | |
Rep 804
09-12-2016, 10:54 AM | #4 |
3442
Rep 79,211
My apologies on the misread but I still stand firm your nozzle size is too big, especially with the amount of potential water that is spraying in.
For example, if you were to run just water the nozzle size would be 1 or 2 GPH. You're at 16 GPH. So at full spray and 50/50 mix your still spraying 8 GPH of water. Too much water will lead to quench, spark plug blow out and misfires. Increase the meth concentration and that will lighten the load on the HPFP too, you'll also be spraying less water. Or cut right to the solution of the problem and run a 10-12 GPH nozzle. If that doesn't fix it still, check your spark plugs and gap. |
09-12-2016, 11:00 AM | #5 | |
Rep 804
09-12-2016, 11:12 AM | #7 | |
Rep 804
below are clean logs of the same 1000cc nozzle running 50/50 mix...hpfp liked it a bit better than 60/40 http://www.datazap.me/u/msport335/e6...og=0&data=4-22
09-12-2016, 11:17 AM | #8 | |
3442
Rep 79,211
You are running a 16 Nozzle, which is over 40% more meth/water so are you making 600WHP cause that would be the only reason to run that much? I understand you had a clean log once before but then again, the only red flag in your setup that I can tell from here is the fact that you are running enough meth/water for almost 2 vehicles. It's a quick fix to prove me wrong and then we can go onto look into other problems. Instead of second guessing me, please reduce your nozzle/GPH/CC and see how your logs look, I'm very confident that would fix your issue. I've also noticed anomalies in your STFT between both logs so something is going on with fuel. Whether the meth/water has to do it with or your HPFP I'm not sure. That's why the easiest potential solution is adjusting your meth/water amount. |
09-12-2016, 11:21 AM | #9 | |
Rep 804
09-12-2016, 11:23 AM | #10 | |
3442
Rep 79,211
CM10 is 630 FYI Also FWIW I used to run an M7, then M10 then M12 and M14 nozzle. After the M10, there was no benefits. I eventually switched to an M5 and M7 nozzle and everything was much improved. The large nozzles have potential for poor atomization and large water droplets. The smaller nozzles atomize much better. Down the road, you may want to consider two small nozzles. Guys who were really serious about methanol were running 3 or more small nozzles to ensure atomization. |
09-12-2016, 11:26 AM | #11 | |
Rep 804
cm10 is 800 since im running 25/26 tapering to 19/20 i should now be in the 475-500whp range (hopefully!)
09-12-2016, 11:30 AM | #12 | |
3442
Rep 79,211
http://www.convertunits.com/from/cc/min/to/gal/hr |
09-12-2016, 06:24 PM | #13 | |
Rep 804
hpfp is still dipping very low http://datazap.me/u/msport335/e60-v2...og=0&data=4-22
09-12-2016, 06:31 PM | #14 |
Rep 2,084
What plugs are you running? You could be blowing out the spark. On my turbo silverado running 50/50 meth/water I went to a colder plug and it started missing. Went back to a stock temp plug and it was fine.
2013 135is DCT Carbon Black Metallic |
09-12-2016, 06:34 PM | #15 | |
Rep 804
have a feeling its injectors now
09-12-2016, 06:59 PM | #16 |
3442
Rep 79,211
Yea that rail pressure is getting very low. It could be HPFP.
Are the injectors a recent index 12? IF not you should definitely change for good measure. LPFP looks ok. |
09-12-2016, 07:01 PM | #17 |
Rep 804
injectors are still originals ....index 6 ....car now has 75k miles on it
09-12-2016, 07:20 PM | #18 |
Rep 615
i have the AEM kit and im running FBO 91 gas and using the large nozzle in the kit as AEM says that i should be..is it better to downsize? of is the AEM large nozzle ok
09-12-2016, 07:30 PM | #19 |
Rep 804
i would definitely downsize the nozzle and log
09-13-2016, 11:46 AM | #20 |
3442
Rep 79,211
09-25-2016, 09:54 PM | #21 |
Rep 804
just had my HPFP and injectors all replaced by dealer last week.
tried running the 500cc nozzle and 60% meth with the e60 kill map and got the misfires again due to the hpfp dipping too low today put in the 1000cc nozzle and 80% meth and no more misfire , hpfp doesn't dip as low either ...however STFT's get pretty negative towards high rpm. so question is do i run pure meth and ramp in the progressive controller at a slower rate so trims don't run so negative or keep as is? controller in these logs is set to 8 to start -12psi full spray http://datazap.me/u/msport335/e60-v2...og=0&data=4-22
09-26-2016, 01:59 PM | #22 |
Rep 780
Looks like your trans is slipping into gear a little. Just something i noticed but maybe that's the way its supposed to look? Mine doesn't do that though...
