10-07-2016, 08:12 PM | #1 |
Rep 1,893
Drives: M5 CS / iX 50i
359 ZCP Wasnt meant to be :(
I must have misread the offsets from one of the posts on here- looks like the rear wheels stick out to far; but looks damn good in my opinion.
Pics before going back to stock wheels
See our discounted BMW models here: https://docs.google.com/spreadsheets...OBuq9ee5ZhiOA/ https://www.instagram.com/day_laborer/ (DM me from this account) Email: nextlevelautobrokersdc@gmail.com |
10-07-2016, 09:07 PM | #2 |
Rep 3,081
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [6.50] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
Doesn't seem to poke excesively, what size tire are you running on them?
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
10-07-2016, 09:20 PM | #3 |
Rep 2,560
Drives: Rapidly from A to B
Looks like trouble in the back. I'm surprised you're not rubbing on hard bumps or on high speed hard cornering. What wheel size and offset? What tire size and offset?
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
10-07-2016, 09:58 PM | #4 | |
Rep 1,893
Tire sizes are 255s front and 275s rear. The rears poke out, only drove around the neighborhood before going back to stock
BAN_M2C4186.50 |
10-10-2016, 08:34 PM | #5 |
Rep 247
Looks great and is my goal to run 4 fronts for winter tyres.
Don't suppose you have time to trial fit a front on the rear to double check caliper clearance 😬 |
10-10-2016, 10:32 PM | #6 |
Rep 1,893
Would definitely clear on the M2, but will require different size lug nuts for sure
10-11-2016, 11:24 AM | #8 |
Rep 1,893
i think i was wrong, some reason I was thinking rear and front lugs are different sizes (would be in cases of spacers)
Perhaps same lug screw sizes would just be fine.
10-11-2016, 12:18 PM | #9 |
Rep 13
You can make these work...if you plan on lowering the car the rear wheels will give you enough camber to clear them...
1988 BMW E24 635csi - Royal Blue Met./Natural Sport Leather - Bilstein Coilovers - AC Schnitzer Type 1 Monoblock 17x8.5 2017 BMW F87 M2 - LBB/BLK W/ BLUE STITCHING SUNROOF - 6MT - 03/17 PROD |
10-11-2016, 12:50 PM | #10 |
Rep 247
06-26-2017, 05:35 AM | #11 |
Rep 34
Hey, I'm thinking about those 1m wheels on my m2. With 245 in front and 265 in the rear. Whats the issue with the rear? looks good to me. I'm now riding stock wheels with eibach pro kit and 10 mm spacers all around.
06-26-2017, 08:59 AM | #12 |
Rep 766
Wheels look great. Done see the problem unless you’re going to drop the car. And even then you could still make it work.
If you think this is a problem you should have seen the 20x11s I used to run |
06-28-2017, 03:02 PM | #13 |
Rep 1,893
The rear tires stuck out a few millimeters past the fender- If I had gone with 265/35/19s it would had worked.
Perhaps if I had Michelin tires instead of these square edged Yokohama AD08Rs, it may also work. Alas, sold the E92 M3 along with the wheels.
