10-17-2016, 06:20 PM | #1 |
Rep 693
About to order 340..need opinion on options
Like title states.
About to order 340i With m sport And m suspension Manual transmission. Is m suspension worth it? What other options are are must haves? Trying to keep payments low Any info be great |
10-17-2016, 06:50 PM | #2 |
Rep 254
Drives: 2020 BMW M340i xDrive
xDrive or RWD?
Assuming you want a sportier ride... The xDrive model comes with the standard suspension even on M-Sport, so I would recommend the Adaptive Suspension (which will firm up the ride on Sport/Sport+ mode). The RWD model comes with the 704 suspension with M-Sport - which I've never tried personally - but I've heard good things about it. In this case, I think the 704 suspension is probably better than the Adaptive Suspension. |
10-18-2016, 09:09 AM | #4 |
Rep 521
I opted for adaptive suspension on my xDrive. I think having the option to be comfortable when driving on shit roads and stiff when on good roads is an awesome feature for the price. I don't lower my cars, so I'm not concerned with that aspect (if you want to replace the dampers, you're either throwing away the money you spent on adaptive, or spending a lot more on adaptive aftermarket dampers). Plus there are options for lowering with the stock dampers (dinan sells stuff, for example).
I'd also say get the lighting package. You might not think you need it, but the adaptive LEDs are also brighter. (See the headlight results here: http://www.iihs.org/iihs/ratings/veh...s-4-door-sedan The adaptive LEDs even in low beam mode light up further down the road) If you want to keep payments low, that's probably it. Personally I'm more of the opinion that I'll be happier with the car getting a lower model with all the options than a higher model with few options, and it's kept me happy with all my previous cars, so my 340 is basically loaded. |
10-18-2016, 09:37 AM | #5 |
Rep 10,319
I also suggest to get Adaptive M Suspension. It will help minimize the body roll and floaty symptoms of base suspension behavior. Are you leasing or buying the vehicle?
10-18-2016, 11:54 AM | #6 |
Rep 8,942
Def get the suspension and brakes too
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
10-18-2016, 12:22 PM | #7 |
Rep 693
Thanks for suggestions.
Ended up ordering 340i xdrive M sport M adaptive suspension. Manual transmission. Alpine white Looking to keep payments down. Live in NY $2000 total out of pocket 36month/12k miles $518 a month. I think it's a good deal. |
10-19-2016, 08:26 AM | #8 | |
Rep 8,942
2022 Macan S
