FS: E92 12" Corner Molded Enclosure w/ ID Sub and Alpine AMP $420
10-17-2016, 09:03 PM | #1 |
Rep 240
FS: E92 12" Corner Molded Enclosure Box w/ ID Subwoofer and Alpine Amp
$380 PICKED UP in Westwood Chevron - Santa Monica and Westwood Blvd - right off the 405 Santa Monica exit. This will be a COMPLETE & PERFECTLY WORKING plug-n-play subwoofer set up with all wiring and everything required to get you that perfect low frequency thump. Hardly uses up space in the trunk. Takes less than 20 min to install. *You MUST have Logic7 and an E92* ID 12 inch Subwoofer Alpine MRP-450 amp (400W RMS) Logic7 harness/LOC RCA cables and amp power kit Logic7/HK harness/LOC is exclusively designed to add a sub/amp to the OEM amp. No OEM wires cut, spliced or tapped. Install example: http://www.e90post.com/forums/showthread.php?t=581166 Last edited by surfcali; 01-02-2017 at 12:30 AM.. Reason: price drop $380 |
01-10-2017, 06:46 PM | #9 |
Rep 649
Drives: F80
how it sound? any vids?
01-11-2017, 01:28 PM | #11 |
Rep 649
Drives: F80
04-28-2017, 11:33 AM | #14 |
Rep 240
not sure, those specs were not provided to me but you can guess using the space located in your trunk where it goes in and look how far it sticks out in the pic provided.
