10-26-2016, 12:39 PM | #1 |
Rep 337
Drives: '17 M2 DCT BSM
How to replace mirror caps
Removed the mirror caps without tools and installed a pair of CF ///M style ones. Looks good to me
Got them from here: http://bit.ly/2fWzgAS Sounded bad but I was told this method (pulling out the cap sharply) would work and decided to give it a try.
Check out my M2 YouTube channel: The HyperCar Collective
10-27-2016, 02:45 AM | #3 |
Rep 337
Either that or stupid... But incidentally this time I was assured, by I friend who did this more than 100 times (he says), that this would not break the caps.
Anyway, they look good!
10-30-2016, 07:25 AM | #5 |
Rep 337
After having these installed for a few days, I honestly do not understand how BMW did not include this at least as an aftermarket OEM part. It transforms the car from many angles and makes it look quite a bit better imho.
11-04-2016, 03:17 PM | #7 |
Rep 743
11-04-2016, 03:46 PM | #8 |
Rep 957
11-05-2016, 05:04 AM | #10 |
Rep 337
got them from http://bit.ly/2fWzgAS.
erchi1166.00 |
11-05-2016, 02:38 PM | #11 |
Rep 2,577
OP, I got a pair of m performance CF mirror cap but I lost the screws and washers that come with it. Am I still able to install it using old screws from stock mirror cap?
Lemania 2320
11-06-2016, 03:21 PM | #12 |
Rep 337
I have no ideia about which screws you mean. My caps didn't bring any screws or washers and you most certainly do not need to remove any when removing the original caps.
11-08-2016, 06:26 AM | #13 | |
Rep 2,577
Lemania 2320
11-08-2016, 08:41 PM | #14 |
Rep 2,577
Sry for losing the pics. See below.
Lemania 2320
11-08-2016, 09:49 PM | #15 |
Rep 1,017
11-09-2016, 01:59 AM | #16 |
Rep 1,514
11-09-2016, 02:39 AM | #17 |
Rep 337
Yeah, that's strange... The clips on mine looked exactly like the originals.
11-09-2016, 03:21 AM | #18 | |
Rep 2,577
I bought it from ECStuning. https://www.ecstuning.com/ES2569799/
Lemania 2320
11-10-2016, 02:44 AM | #19 | |
Rep 337
11-10-2016, 10:54 AM | #20 |
Rep 182
I'm having the same issue. I bought the OEM CF mirror caps, but they don't have clips, instead have screws.
Getting the existing mirror caps off was simple, but does it require removal of the mirror to put on the carbon fiber oem caps in order to screw them in? If so, that is quite unfortunate. They should have just used clips. |
11-10-2016, 11:56 AM | #21 | |
Rep 182
After you do that, you put the caps on and screw them in with the washers from the inside, then pop the mirror back into place. |
11-10-2016, 11:56 AM | #22 |
Rep 254
Pretty sure this is the process
http://f30.bimmerpost.com/forums/sho...d.php?t=708155
2017 M2 - AW DCT - BM3 93 oct, Pure Stage 2, FBO, happy
2013 BRZ - was a GREAT car... just not fast enough 2008 VW GTI - first experience with boost 97 Integra GSR - crashed it |
SeanWRT3179.00 CommitConfirm474.50 |
