Cycle ABS/DSC?
05-05-2008, 01:39 AM | #3 |
digging for gold
Rep 50
The only way is to hook up the car to the MODIC.
Otherwise flush the system with fresh fluid, activate the ABS by going out for a drive and slamming on the brakes (be careful!), then bleed the brakes again. |
05-05-2008, 08:25 AM | #4 |
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
There is a procedure with the newer audis...hooking up to a VAG tool..but I dont remember exactly what that was. I am not familiar with the BMW equivalent.
Car is now gone .... :-( |
06-19-2008, 11:57 AM | #5 |
Rep 494
anyone can point me to DIY for bleeding our brake system before I track? I see the bleed nipple but not sure if the old school method of bleeding brakes works the same on these cars.....just checking first.
06-19-2008, 12:43 PM | #6 | |
Rep 1,714
I've done this probably 10 times already, so I know it works. |
06-20-2008, 08:50 AM | #7 |
Rep 494
noted good sir! I figured the old school method still worked....
06-20-2008, 10:21 AM | #8 |
Rep 4,380
usually the order is...right rear, left rear, right front, left front. Yeah..the classic method works
06-20-2008, 11:27 AM | #9 |
Rep 1,714
Yes, listen to S4to335.
Try using the RBF600. I tried ATE Blue and #1, it stains everything blue and the dealer gave me crap about it....and #2 I still got fade on ATE Blue. Now with RBF600, the pads go waaaay before the fluid. |
06-20-2008, 01:12 PM | #10 |
Rep 494
+1 on RBF600....already called my shop for quote on brake flush.
big ups to S4to335 for the wisdom! appreciate everyone's input, definitely gaining the experience on track and off by soaking in what some of you "experience" yourselves.... |
06-21-2008, 12:53 AM | #11 |
Rep 1,826
Drives: E92 335i
According to Tech Talk the only way to effectively flush the ABS unit is with a GT1 or similar.
