intercooler, for FBO stock turbos 7" or 5"
11-17-2016, 12:46 PM | #1 |
Rep 175
Bout that time as Black Friday deals are showing up. Full bolt on N54 with stock turbos, what say is the better size to go with. I dont plan on upgrading to larger turbos. My goal is a custom tune on pump 93 gas. Im lacking an intercooler and may as well install it while Ive got my car in the air doing my pressure plate.
11-17-2016, 02:13 PM | #2 |
Guest
Rep n/a
Drives:
11-18-2016, 01:56 AM | #4 |
Rep 337
I went with VRSF's 7 inch as my first upgrade. I only had to cut off a really small amount of shroud.
I'm so glad that I went 7 in the beginning, because since then I've added on a bunch of other stuff and have been happily boosting 21psi. |
11-18-2016, 06:46 AM | #5 |
Liberty or Death
60
Rep 90
Drives: 2007 E92 335i
Another vote for the VRSF 7" Buy once, and be done.
2017 BMW 340i
2007 E92 BMW 335i 2007 E90 BMW 335i - Sold |
11-18-2016, 02:49 PM | #6 |
Rep 74
Drives: 2008 335i Coupe 6-speed
Bought the 5" Stepped. It's last on my list for FBO, I'm only autocrossing occasionally and I'm not going to replace my turbos anytime soon. Plus, I hear the difference if you're only going for 400hp, it's negligible.
'08 E92 335i 6MT Coupe SGM | MHD Stage 2 93oct | Cp-E CP | AA BOV | DCI | VRSF DP | VRSF 5" Stepped FMIC | Apex Arc-8 | Cyba Air Scoops | Failing HPFP....
11-18-2016, 11:43 PM | #11 |
2097
Rep 43,350
The 7" HD is an incredibly dense core (similar to garrett) in comparison to the regular 7". Single/multiple gear pulls result in lower intake temps at regular cruising temps. Here's a 2-4 gear pull, 91 degree start, 100 degree finish. 9 degree rise over 3 gears.
11-19-2016, 12:27 AM | #12 |
Rep 589
Drives: E90 M3/E92 M3
I'd go for at least 6" or 7". I've seen some logs with IAT rising with 5" FMICs after multiple runs.
11-19-2016, 02:14 AM | #13 |
Custom User Title
50
Rep 247
ill also add a plus to the VRSF 7". a little extra cutting of the front shroud (which you can do waiting for delivery since your car is up already ) and then just throw it in like normal.
you never know what the future holds. one and done as they say. |
11-19-2016, 02:17 AM | #14 | |
Rep 960
my wagner evo 1 perf is great can't see the need for anything more on stock turbos. best part is it's direct bolt in. took me about 15- 20mins to install in my garage on stands. |
11-20-2016, 09:03 AM | #15 |
Maximus Decimus Meridius
1132
Rep 4,586
Wagner is also double the price of the VRSF.. But if you got it to spend, for the same results, sure why not..
F30 335i Melbourne Red Metallic M-Sport Package |
11-20-2016, 01:31 PM | #16 | |
Rep 960
wagner actually fits properly with no cutting required using stock connectors. |
11-20-2016, 03:49 PM | #17 | ||
BimmerPost Supporting Vendor
24477
Rep 191,448
Thank you Quote:
There a ton of deals in the vendor section on VRSF, Wagner and Active Autowerke @FCobra94 posted a link of an FMIC thread i created, take 5 minutes to read it very informative
titium326.50 |
