11-28-2016, 09:58 PM | #1 |
Rep 91
Carbon fiber spoiler install
Anyone who has had this installed. Is it all double side tape or attached with bolts? Looking to have installed just after taking delivery but company doing my xpel coverage and tint says can also install if double side taped.
Any info would be appreciated! |
11-28-2016, 10:19 PM | #2 |
BMW Newb
582
Rep 903
Typically installed with 3M tape. Another option is to use Betalink adhesive, but that is typically harder / impossible to remove if you mess up the initial install...fine to just stick with the double sided automotive tape.
01-20-2017, 01:13 AM | #5 | |
Rep 220
edit: I googled spoiler installation and apparently there's no magic to the adhesive. it's just mark it, remove the backing and stick it on. I was thinking there was some special sanctioned method. For anyone else wondering in the future, I think the best method I saw was to lay it out where it needs to go and then put a few pieces of painters tape on the forward/leading edge. then just pivot up using the tape as a hinge, remove the backing, and lay it back down. Actually looks pretty simple.... Last edited by CantComplain; 01-20-2017 at 01:36 AM.. |
01-20-2017, 05:59 AM | #6 | |
Rep 486
01-21-2017, 02:47 AM | #7 |
Rep 174
01-21-2017, 05:11 AM | #8 |
Rep 337
Drives: '17 M2 DCT BSM
Will be doing the same with an AutoID CF spoiler probably next weekend.
Check out my M2 YouTube channel: The HyperCar Collective
01-21-2017, 06:18 AM | #9 |
Rep 120
Fishing line and adhesive remover is a safer way of removing the original spoiler. I wouldn't advise doing it the way in the video. Heat it up before running the line if the spoiler is cold.
The way they attach the new one in the video is the best way I know of. Don't make the mistake of pulling off all the backing before you put it down! |
FrozenGT1136.00 |
01-27-2017, 10:51 AM | #10 |
Rep 14
Could someone give me the exact dimensions of this spoiler (how high it is and how far it sticks out from the boot)?
I'm having a car cover made and the manufacturer wants dimensions since it'd a non-stretchy material. Thanks alot in advance! |
02-08-2017, 12:34 AM | #11 |
Rep 435
Is it just me or does the spoiler look like it is seriously pulling up towards each end. The left side doesn't look great in the video after it has been installed.
02-08-2017, 02:05 AM | #12 | |
Rep 229
I've watched 4 or 5 youtube videos. They're all mostly the same. Haven't heard of any super secret tricks. |
02-08-2017, 10:37 AM | #14 |
Rep 435
02-08-2017, 04:55 PM | #15 |
Never underestimate the Home-Bowl
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
Mine too. Dealer installed.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
02-23-2017, 06:12 PM | #16 | |
Rep 4,551
Drives: 2015 328d xDrive
02-23-2017, 08:25 PM | #17 |
Rep 435
my gap is less than that but still noticeable to someone who considers themselves OCD. I dont think the betalink will make a difference because on my spoiler the edges literally wont touch the trunk even with a decent amount of pressure. It's almost as if during manufacturing the edge slightly curve up.
termigni1081.00 |
02-24-2017, 05:30 AM | #18 |
Rep 60
07-25-2018, 03:52 PM | #20 | |
Rep 1,899
Similar ones that imo look better are AC Schnitzer or PSM. Both of these come in 2 variants, with the "notch" on the center or completely rounded off |
07-26-2018, 01:41 PM | #21 |
Rep 2,956
I concur with posters above. The M performance CF spoiler fitment is poor IMO. I did everything possible to ensure a proper fit (polished off old adhesive residue followed by IPA wipe down, followed by 3M adhesive promoter. I spent a good 40 minutes lining things up making marks and measuring to ensure perfect fitment and even taped the corners down for a week and eventually both edges lifted. BMW needs to have the molding very slightly changed to have the ends taper slightly down. That would ensure the ends don't lift and there's no danger of the middle section separating as that part has a very strong bond. I realize CF is more difficult to get perfect but this is one of the worst OEM fitments I've ever seen on any car which is inexcusable for the money they charge for the piece.
07-26-2018, 04:56 PM | #22 | |
Rep 66
https://f87.bimmerpost.com/forums/sh....php?t=1510137 |
nioh_lbbm21716.50 |
