12-14-2016, 03:06 AM | #1 |
Rep 619
Re-ordered After Incorrect Data Online - Better Result
Well, after ordering at end November, dealer advised some issues (combined items not same as initial online configuration), but plus side is prices went down so could add toys. Company car so trying get best bang for buck and avoid CO2 based tax)
520D M Sport Auto Bluestone Metallic Black Leather - Blue Stitching Enhanced Bluetooth - w/wireless charging Folding side mirrors w/memory Full electric seats w/memory Variable Damping Control High Beam Assistant Sun Protection Glass Rear View Camera Online Entertainment Advanced Speaker System 676 12v Socket extra x 2 WiFi Hotspot Delete M Badges on sides Delete M Sport Suspension Delete Model Designation Delivery Date 20th March, just under £44k
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud Alpine White F10 M Sport - Gone to Stud |
12-14-2016, 01:18 PM | #3 |
Rep 619
Wi-Fi can't be ordered on it's own (needs Enhanced Bluetooth w/Wireless Charging, so added that)
And although it is in my list, I couldn't delete M Sport suspension if I have VDC... ..weird but a pity, tried a couple with Sport Suspension before and quite unforgiving over lumps and bumps The online configuration is all fine now... it was a Beta or something when I first tried or, didn't link all the options properly
12-14-2016, 01:58 PM | #4 | |
Rep 29,202
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
01-06-2017, 04:37 AM | #5 | |
Rep 619
Also good is you have to ADD smokers package, not default anymore 20th March, roll on
01-06-2017, 05:14 AM | #6 |
Rep 10,185
Technically VDC deletes M Sport Suspension
BMW if you are reading, I need a job, Please. |
01-06-2017, 06:02 AM | #8 |
Rep 29,202
Right, I know. Poorly worded on my part.
As I understand it, no. Only m-sport suspension will lower the car.
01-06-2017, 07:30 AM | #9 | |
Rep 10,185
You can actually see it on the German Configurator Click "Details" under M Sport Pack and then change between the Suspensions available. It will drop the car height only with the M Sport suspension Not quite so easy to see below But if you save both images and then switch between the 2 you will see it go from lower to higher suspension. Lower is M Sport suspension
01-06-2017, 10:24 AM | #10 | |
Rep 29,202
So I played around a bit to see if the new combo, xDrive and M-sport suspension also get a drop, and it did. But then I checked to see if 530 and 540 got different sized M-sport brakes, and the configurator shows the same size brakes.
