12-21-2016, 03:27 AM | #1 |
Rep 56
m sport brakes
Hi Everyone
Would anyone care to speculate if the m sport brakes would fit ok with an 18 inch wheel? Only available with 19 inch wheels on UK Configurator... Cheers |
12-21-2016, 06:46 AM | #2 |
Rep 10,185
M Sport brakes require 18" wheels
You can see this on the German configurator aswell ( add M Brakes to a standard car and it automatically adds 18" wheels) M Performance brakes require 19" wheels The actual brake disc sizes are 540i Euro Standard brakes are Front 348x36 Rear 345x24 M Sport brakes are Front 374x36 Rear 345x24 M Performance are Front 395x36 Rear 370x24 530i Euro + 530d Euro Standard brakes are Front 348x30 Rear 345x24 M Sport brakes are Front 348x36 Rear 345x24 M Performance are Front 395x36 Rear 370x24
BMW if you are reading, I need a job, Please. Last edited by E90Fleet; 12-21-2016 at 07:08 AM.. |
Mikej0h50.00 |
12-21-2016, 07:01 AM | #3 |
Rep 29,202
Should not 17" fit over the smaller M sport brakes on the 530, I see they won't fit on the 540i.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
12-21-2016, 07:43 AM | #4 | |
Rep 10,185
Remember it is a different caliper design for the 530i M Sport brake( Fixed vs Floating) So the caliper may be larger causing them not to fit 17" wheels
BMW if you are reading, I need a job, Please. |
12-21-2016, 09:32 AM | #5 | ||
Rep 29,202
12-21-2016, 10:21 AM | #6 | |
Rep 10,185
The spoke clearance is not much different between the different wheels 17" 7,5J ET:27 18" 8.0J ET:30 M18" 9.0J ET:44
12-21-2016, 10:34 AM | #7 |
Rep 56
thanks
Thats great info especially the german configurator.
I'll probably get the msport and pick up a set of 18s separately as the roads here are poor Thank everyone. |
12-22-2016, 06:46 AM | #8 |
Rep 10,185
For info,
G30 Caliper Manufacturers: Front Standard 1 Piece 4 Piston - Continental 2 Piece 4 Piston - Brembo Rear All - TRW
12-27-2016, 02:54 PM | #9 |
Rep 29,202
I was looking at the M sport brakes (blue) on the M550i and the M performance brakes red).
I notice the calipers looks to be the same just different colors. But I assume the M sport brakes are 374 mm for the M550i as it is for the 540i, but the M performance brakes are 395 mm. So how can the same caliper fit different sized rotors?
12-27-2016, 03:28 PM | #10 |
Rep 5,140
Similiar for F30.
The M Sport brakes has 340 and 370mm front rotors depending on engine. The M Performance brakes has always 370mm front rotors. The calipers for 340 and 370 rotors looks the same from the outside but the mounting points on the inside is different to fit different rotor sizes. Therefore there are two different part numbers for the blue front M Sport brake calipers for F30. I guess the same is valid for G30 M Sport and M Performance brakes. |
540iSUP704.00 |
12-28-2016, 06:01 AM | #11 | |
Rep 10,185
Why do you assume 374mm ? The M550i comes standard with 19" wheels. This may be because of the brakes. So they may be 395mm standard.
12-28-2016, 06:46 AM | #12 | |
Rep 29,202
I don't know if this is still the case with the new M550i, or if BMW really has gone for 19" as minimum wheels size. Here's the 540i M sport with 374 mm brakes, but it's hard to see if it's the same as the M550i because of all the spokes.
12-29-2016, 06:00 AM | #13 | |
Rep 10,185
So maybe only late January
01-09-2017, 06:06 PM | #14 |
Rep 29,202
One more of the M550i.
08-13-2022, 05:18 PM | #15 |
Rep 66
Drives: BMW G30
