12-21-2016, 01:18 PM | #1 |
5380
Rep 3,793
M2 vs M140i Dyno
Featured on BIMMERPOST.com Both cars were using 99 RON Fuel (93 Oct) and have around 2500 miles on the clock. The M140i is rated by BMW at 340 BHP and 369 lb.ft torque whereas the M2 is rated at 370 BHP 343 lb.ft torque. Most of the modern BMW turbo cars make a little bit more than BMW quote on our Dyno Dynamics dyno. The M140i surprised us! Red Line is M2 and Green Line is M140i. Flywheel Wheel Power As you can see the M140i had a higher peak torque figure just like BMW figures suggest. Midrange of the M140i is also stronger but the top end of the M2 is slightly better. Looks like the B58 should be a great platform for tuning. |
12-21-2016, 02:12 PM | #2 |
Rep 95
So even the supposed 400HP for the M2 CS won't be enough to create a real performance gap between these cars.
And about the performance difference between the actual M2 and the Mx40i..we should probably not get into that. |
12-21-2016, 02:19 PM | #3 |
Rep 1,153
"Performance" is a function of far more than horsepower and torque.
17
Eddien1231861.00 Kover3107.00 AndrewC198910932.50 filet.M2c784.00 jeremicium170.50 ried793.00 Chicken_Joe608.00 Pentium184.50 BAN_M2C4186.50 bradleyland1503.50 williewonkerz60.00 Bluenose-2er576.00 iatacs19460.50 TailgatingBMW11.50 ilovewagons425.50 Dav3948.50 krizze928.00 |
12-21-2016, 02:54 PM | #4 | |
Rep 549
Drives: The Bus
Garage List 2017 Ford Focus RS [0.00]
1971 Mk3 Austin Min ... [0.00] 2013 MINI R56 GP [0.00] 2013 MINI R55 Clubvan [0.00] |
Having seen the dyno results it kinda stings a bit. I would have liked the M2 to have had a bigger performance gap. I wonder if I would have been just as happy in a well spec'd Mx40i? On a daily driver I'd trade the better performance at the lower and mid ranges over a higher top end. Maybe they should build a B58 'LCI' M2? |
12-21-2016, 04:19 PM | #5 | |
Rep 571
12-21-2016, 07:33 PM | #7 | |
Rep 1,759
You think the S55 M2 CS will just have 400hp? Think along the lines that how much the M3/M4 S55s had been underrated and you will have a more realistic figure with the CS. |
Dackelone10606.50 PunkSinatra78.00 |
12-21-2016, 07:39 PM | #8 | |
Rep 1,759
To further reduced weight by 70kg is totally unrealistic and even then it won't be 'miles' ahead of the 140i. 70kg is just the weight of a small adult and won't affect much in a straight line acceleration. |
phoenixbmwlife1912.50 |
12-22-2016, 02:55 AM | #10 |
Rep 2,577
Speaking as a m2 owner, I am irritated looking at the graph.
1) N55 and B58 put down identical top end. You will think N55’s maxed out small turbo should spool faster as a tradeoff and make better low end torque. Well, it didn’t happen - B58 has longer stroke and higher compression ratio, which significantly helps down low when pressure isn’t built up. 2) Higher compression ratio means greater timing pull at high PSI and thus less efficient power and less tuneability. Well, it didn’t happen - B58 works just as fine at 15psi as N55. 3) Longer stroke means less free revving. Well, it didn’t happen, B58 rev all the way up to 7K rpm, nothing less than N55. I would like to thank you for using RON99 so the N55 torque didn’t fall on your graph as much as we saw it does elsewhere. Now you better tell me the 2 dyno weren't performed the same day please
Lemania 2320
Robin_NL8725.00 Nine Lives602.00 |
12-22-2016, 04:14 AM | #11 |
S0THPAW
8725
Rep 7,847
Exactly @ Sean...
BMW/M limited the M2 in any possible way putting in the 'low end' N55. Good old N54 is way more sophisticated/tunable and 'high end'. Only the sound is nice but for the rest it lacks grunt and power like S55(and high tech engineering) I'm going to buy a bigger turbo for my N55 next year.... Cheers Robin |
12-22-2016, 05:08 AM | #12 | |
5380
Rep 3,793
I wouldn't get too hung up on the figures. The M2 is more than its engine. |
gorg-0-mish7.50 |
12-22-2016, 06:22 AM | #13 | |
Rep 2,577
I am surprised there hasn't been more reviews/dyno on that setup it's been half a year.
Lemania 2320
12-22-2016, 07:07 AM | #14 |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
Same here. That way I don't have to hear about the superiority of the B58/S55 in CS as compared to the N55. I'm also looking forward to a top end monster.
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp Left lane campers, GTFO! |
440xiGCMsport208.50 |
12-22-2016, 07:37 AM | #15 | |
Rep 95
You already surely know this interesting discussion (especially the 6th post): http://f80.bimmerpost.com/forums/sho....php?t=1206686 And for sure, I know very well that the M2 is not only its motor. I love it at all |
12-22-2016, 08:58 AM | #16 |
Rep 4,525
Yes lets hope so given that there's £20k premium for M2 v M140i.............you could buy an e46 M3 CS with the leftover change !!!!!
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
Alpine F31918.50 |
12-22-2016, 11:05 AM | #17 | |
Rep 886
( there's a thing,system doesn't like the word f*g ) in the performance stakes it doesn't take a genius to see which model has the highest take up...m240i included. |
bora57.00 |
12-26-2016, 01:05 PM | #19 |
Rep 2,400
True, the S55 is one of the most egregiously underrated engines in BMW history. Given produces around ~470 bhp based on dynos (at the flywheel), the M2 CS version will probably be around ~440 bhp assuming the same proportion of under-rating.
Someone thinking the B58 will be some bargain engine that produces as much bhp as a dedicated M-engine and BMW will be "under-charging" for it, is simply deluding themselves. |
