Squirrelly handling after wheel spacer install?
01-08-2017, 09:58 AM | #1 |
Rep 338
I just installed wheel spacers for the first time on my e90 328i. Afterwards I noticed the handling felt slightly jittery on the freeway, especially over rough roads.
Is this to be expected with the wider track? Anything I should be concerned about? I'm on stock suspension and wheels. Spacers are 10mm front and 15mm rear. I did check the lugs after the first 25 miles and everything was tight. I also rotated the tires at the same time if that makes any difference. |
01-08-2017, 11:01 AM | #3 | |
Rep 535
01-08-2017, 11:16 AM | #5 |
Rep 2,960
not normal - I'm running 10/15 on my 2011 LCI E90 and its smooth as can be - same holds true for my 2016 435 GC. On both my cars I went with hub-centric spacers and longer bolts.
Perhaps you're not running hub-centric? If you are, then it's time to dig a bit deeper into the situation Good luck! |
01-08-2017, 11:49 AM | #6 |
Rep 338
Car only had 47k miles on it... should I really be concerned about the suspension at this stage? What would I look for if it was going bad?
Tire rotation might make sense. Rears were pretty worn and fronts were like new. Now the fronts are the worn ones and I swapped left and right as well so presumably that threw things off a bit. I did it myself so no tire balance or alignment has been done. Honestly it's not really a bad feeling, I was just surprised as it seemed like slight movement of the steering wheel would cause the car to move around more than it did before. This is a new car for me so maybe i just didn't notice before. |
01-08-2017, 01:33 PM | #7 |
Rep 1,157
added scrub radius will increase kickback and steering stiffness... the combination might be making you feel like it is more twitchy until you are used to it.
01-08-2017, 01:43 PM | #8 |
Save the manuals!
6035
Rep 6,754
No tire balancing and no alignment, and worn tires.
And you're still wondering why it's acting up?
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
01-08-2017, 02:38 PM | #9 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Yea as long as you didn't make a mistake switching the bolts for the 10 & 15mm spacers when you rotated the wheels and have hub centric spacers. You need at least to rebalance the tires after rotating.
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
01-09-2017, 03:28 PM | #11 |
Rep 338
My spacers are hub-centric. Renn Motorsport with extended lugs.
To be clear, the car feels fine 98% of the time. It's mainly when I hit a large rough patch in the freeway (LA roads are horrendous) that the car seems to "walk" to the left or right a bit. It's not terrible and as long as I'm paying attention everything is fine. It just surprised me as this is otherwise a very stabile and planted car compared to my last car (mk6 GTI). I can't imagine that alignment has much to do with it since it is smooth and straight under normal conditions. I'll get an alignment and balance soon as well. Anyway, I'm not too concerned about it. Mostly was just curious if others had noticed twitchier handling with spacers. |
01-09-2017, 03:35 PM | #12 | |
E39
134
Rep 286
01-09-2017, 05:40 PM | #13 | ||
Rep 338
01-09-2017, 06:41 PM | #14 |
Rep 96
Drives: 2011 BMW E92 335i V. Red/SB
Sounds like tire related.
Had the same problem with worn run-flats. Car moved around on rough roads similar to 'tramlining' |
dancing__narwhal141.50 |
01-09-2017, 07:16 PM | #15 | |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
01-09-2017, 07:19 PM | #16 |
Rep 338
01-09-2017, 07:23 PM | #17 |
Rep 338
Really depends where you are. LA is a large area. Some roads are great, others pretty rough. Also depends on your frame of reference. I don't live in LA but every time I drive through (which I did 4 times this weekend) I'm struck by how rough the roads are.
01-09-2017, 08:08 PM | #18 |
Rep 3,475
I drove pretty much all over from Malibu (near el matador beach) to Long beach and everywhere in between. Besides the large dips in some intersections for drainage (mostly near the airport it seemed) I thought they were like glass compared to ours here.
01-10-2017, 03:35 AM | #19 | |
Rep 11,905
If i dont tighten the wheel nuts evenly I get vibration in the wheels, especially cruising on the highway Remove the wheels, make sure hub is clean (free of dirt or rust) behind the spacer, make sure the spacer is pressed up against the hub, then put on the wheels and do up the nuts. I tighten them in a star pattern, finger tight first, then using the wheel brace then finally using a torque wrench to 120 Should be nice and smooth |
01-10-2017, 09:18 AM | #20 |
Rep 595
If its good 98% of the time and its only on the freeway I suspect its the road you are driving on. I know certain inner city highways have grooves or ridges on certain stretches of the highway. I've felt that feeling before because the tires fall into the ridge make the car jitter slightly like its on rails.
01-10-2017, 01:00 PM | #21 |
Rep 338
01-10-2017, 01:24 PM | #22 |
Rep 535
Ditch those RFTs and you ride will get MUCH better both control and comfort wise. No BMW (unless it's a armor plated versions) should come off the line with RFTs - they ruin ride
