Cold Start Misfire/Roughness Issue
01-14-2017, 07:02 PM | #1 |
Rep 196
My 2007 BMW 335i just had all of its injectors replaced with brand new index 12 injectors as well as replaced all of the spark plugs when the injector swap was done. This morning the cold start was kind of rough for a couple of seconds with fluctuating RPM needle, I guess it was enough to throw a "Service Engine Soon" light so I went to go read it at Advance Auto using their OBD scanner and found codes P0304 and P0306 (cylinder 4 and 6 misfire). The car only does that "misfire" roughness during cold starts. When you start driving the car it's fine like normal. Wondering what the problem behind those codes could be? Could it be a HPFP going out? Although I don't really get long cranks? Any help or input would be appreciated. The car has 57K miles on it, thanks.
01-14-2017, 07:13 PM | #2 | |
Rep 325
01-14-2017, 07:44 PM | #3 | ||
Rep 196
01-14-2017, 08:36 PM | #4 |
Rep 337
If you buy an older model, these should all be ripped out and replaced as soon as you buy the car.
Coils, plugs, injectors, hpfp, lpfp, all lambda sensors Get a walnut blast. Were the injectors coded properly? |
01-15-2017, 07:03 AM | #5 |
Rep 196
Yeah I'm assuming the injectors were coded properly, I know he coded them but maybe he made a mistake, don't think so though because when I give it full throttle the car acts like normal, no hiccups or stuff. Walnut blast was done at 55K miles.
01-15-2017, 08:36 AM | #6 |
Rep 460
I would first pull and check the plugs condition then swap to different cylinders. If they are worn replace them. If that doesn't fix it on to the coils. First swap positions and see if it follows them. Replace all of them if you find a suspect one.
It gets more pricey after that. Injector coding issues and fuel pumps. Do you have a tune? |
01-15-2017, 08:52 AM | #7 | |
Rep 196
01-15-2017, 10:22 AM | #9 | ||
Rep 325
01-15-2017, 10:41 AM | #10 | |||
Rep 196
10-30-2018, 06:47 AM | #11 |
Rep 6
Hi. I am having the same issue with my car, runs rough and misfires when cold (sometimes it doesn't like at all to accelerate), but after a ~5 minutes it's smooth, after a few more minutes (~10) it's perfectly fine.
For now I only changed the spark plugs and switched the order of the ignition coils, but nothing changed. Next week I will get a walnut blast, even though I am pretty sure that won't fix my issue. The car has 80k miles. You did not write here, but what was the fix for your car? (and please don't say "buying and M3" :P ) Edit: For me the fastest way to get rid of the roughness of the engine and the misfire is to restart it. I did not wait for it to run smoothly by itself. Last edited by noname00; 10-30-2018 at 06:59 AM.. Reason: adding some more info |
10-30-2018, 07:00 AM | #12 | |
Rep 196
10-30-2018, 07:06 AM | #13 | |
Rep 6
From the original post I understood that you had the issue with the new injectors. I will first try to swap injector 6 with another one, just to see if the misfire moves with it. |
10-30-2018, 07:08 AM | #14 | ||
Rep 196
