01-24-2017, 06:32 PM | #1 |
BimmerPost Supporting Vendor
3885
Rep 54,481
Drives: F80 M3
Dinan Big Turbo for the BMW F87 M2
SKU: D310-0110
For the racing enthusiast, this is the ultimate upgrade to fully maximize the power output of your F87 M2. The compressor wheel inside the turbocharger is increased in size enabling additional boost pressures and thus increased horsepower at higher engine speeds all the while retaining efficiency. Product Description For the racing enthusiast or those just looking for the best, this is the ultimate upgrade to fully maximize the power output of your F87 M2. The compressor wheel inside the turbocharger is increased in size allowing ~30% greater flow thus enabling additional boost pressures at higher engine speeds while retaining efficiency. These are rebuilt factory turbos that are machined to Dinan specifications along with an upgraded thrust system to ensure reliable and prolonged life. In order to attain maximum advertised power gains these big turbos will need to be paired with DINANTRONICS Stage 4, as well as Dinan’s intercooler to fully regulate the boost increase and deliver a polished product although the exhaust and intake are also recommended. Benefits of the Dinan Big Turbo for the EWG N55 Engine: + Factory turbo that is machined to Dinan specifications with an upgraded thrust system. + Larger billet compressor/impeller wheel that allows ~30% greater flow over stock which then enables additional boost to be realized while retaining efficiency. + Peak power: 446 HP @ 6500 RPM and 458 ft-lbs @ 4500 RPM with max gains of 101 HP @ 6500 RPM and 86 ft-lbs @ 4500 RPM when coupled with other Dinan Performance upgrades. + Dinan Installation instructions detail a procedure which is quicker than BMW's turbo replacement procedure saving the end-user money and time at the shop. + Includes o-rings and gaskets needed for complete installation. + Factory matching new car warranty (4yr/50k) when run in Dinan specification. + 50 State Emissions legal; CARB EO # D-176-49. Emission Status 50 State Emissions Legal. California Air Resources Board Executive Order Number D-176-49. Included Notes Turbocharger assembly only, and does not include the exhaust manifold. Includes o-rings and gaskets needed for complete installation. Required Items Installation procedure requires factory-level tools such as BMW ISTA (or equivalent) to adjust wastegate for proper operation. $1766.49 Order here: http://www.hpashop.com/Dinan-Big-Tur...-D310-0110.htm Installation instructions here: http://files.dinancars.com/webresour...3f2fb5675a.pdf ***Due to incredible demand and limited availability of cores the EWG N55 turbo has a waiting list associated with it. Any new orders will be a minimum of 4 weeks away from fulfillment. We are working as hard as possible to minimize those delays.*** Last edited by HP Autosport; 03-29-2019 at 05:54 PM.. |
05-21-2017, 11:55 AM | #17 |
Rep 2,515
How long is the wait for these now?
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo ?22 Tesla Model Y Performance Midnight Silver/White |
06-10-2017, 10:44 PM | #20 |
3885
Rep 54,481
Drives: F80 M3
