E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > DIY-PI Sharp Customs Port Injection Manifold Review.
Reply
      01-26-2017, 02:17 PM   #1
10091989
Drives: 135i FBO
Talking DIY-PI Sharp Customs Port Injection Manifold Review.
Hey guys,
I have been working with a vendor named Sharp Customs for their Port Injection Manifold testing. We now have a usable solution after 4 revisions that fits and functions perfectly but also adds a +1 for engine bling!
This has been very hush hush for the most part but that was because Sharp Customs sells a very large volume of 2JZ intake manifolds and this was an offering they brought to the N54 crowd. At this time I can only confirm the fitment for the N54 (all models USA) for now.
What you get with this kit:
- Aluminum Port Injection Manifold
- Fuel Rail and fittings (6an)
--Also includes an adapter for the return line if needed
- Manifold O-rings
- 4 vacuum ports (underside)
- 4 vacuum fittings for the above ports in various sizes
- All bolts and needed hardware to install
Need to know:
- This will fit very snug and works with all aftermarket Charge-pipes
- You will need to move the Brake Booster Vacuum line (easy)
- You will need to supply your own fuel line fittings and injectors.
-- LS7 style EV6 injectors (shorty style)
- You will need a Port injection controller AI6/BMS
My build list right now:
Jegs Order
QTY Item Cost
2 2 361-809106 FTG -6 90 TUBE SWIV SEAL 17.76 35.52
1 1 361-926106 -6 I FEMALE AN SWIVEL 17.06 17.06
1 1 555-103120 FUEL RAIL FTG. 6AN X 5/16 8.95 8.95
1 1 198-37418 BLUE THREADLOCKER 242 6ML 8.99 8.99
2 2 555-100403 3/8"NPT PIPE PLUG BLUE(2) 4.41 8.82
1 1 Spectre Performance 6038 4pk 1/8" NPT Pipe Plug 5.89
1 1 361-176106 O-RINGS VITON -6 PK OF 10 3.56 3.56
1 1 361-991912 FTG -6 TO -8 RDCR UNION 5.68 5.68
1 1 799-640860 -6ANX5/16SAE FEM LT4 BLUE 18.99 18.99
1 1 555-100910 #6 HOSE PRE-CUT 3-FEET 14.99 14.99
1 1 361-939206 FTNG -6 45 SWIVEL COUPLER 12.38 12.38
ECS Tuning Order:
1 1 11617547242 OEM BMW Intake Runner Gasket 34.72
1 1 13547582931 Throttle Body Gasket 9.08
Injectors I used:
http://www.jegs.com/p/FAST/FAST-Prec...22113/10002/-1
Fitment:
Its a direct bolt on unit that once you get the above parts will need to T off the LPFP -> HPFP line with a adapter to feed the rail. If you have seen any PI install its the exact same as those ones basically. Instead of a spacer this is an actual manifold.
Performance
So far after several 20psi pulls with PI spraying i can say that its a BEAST!! Once the PI starts to work the car hauls all the way to redline and the added fueling is really obvious once it kicks on. I am hoping to dyno after my custom tune is ready from Trebila The car just FEELS like it revs much quicker than before. That is likely due to the AFR doing from 12.8 to a richer 11.9 under WOT. HPFP does not dive anymore either on 100% E85 and my stage 2 LPFP seems to hold the pressure just fine - lowest its dipped is about 54psi nearing redline PI active @ 23psi
Price is set at $540.00 shipped to your door from Sharp Customs and i am not personally selling this either. I am here to offer support in case its needed from those who purchase but that's solely my discretion since I am not paid by SC for forum support. I think this is a GREAT offering and has a great deal of buzz on other forums right now
Last edited by 10091989; 01-27-2017 at 10:28 AM.. Reason: removal of detail not relevant to review.
STR8-6IX537.00
      01-26-2017, 03:31 PM   #2
Tim603
Tim603's Avatar
Drives: 2007 335i E90
2007 335i  [0.00]
Glad to see some more options coming out!
      01-26-2017, 08:32 PM   #3
Sshec152
Drives: 2007 335i coupe
Are adapters needed for the bms pi controller to the injectors or are they a matching plug? Also would having fuel-it upgraded fuel lines with the y built it, negate the need for the y made of an fittings? Or would that not work for this manifold ?
      01-27-2017, 12:08 AM   #4
limitdown
limitdown's Avatar
187
Drives: 2007 335i E93
It's great to see competing offerings coming out
      01-27-2017, 10:30 AM   #5
10091989
Drives: 135i FBO
Yes the EV6 is the connector type used for the AI6 and the BMS PI controller so no adapters are needed. Plug and play.
And yes you are good to go if you have the T line already installed. If you have a PI spacer now you can remove the spacer and use the lines/injectors in this manifold too!
      01-28-2017, 04:05 PM   #6
2jzn54
Drives: 07 E90 335i 6MT
what lb/hr injector are you running
      01-30-2017, 02:02 PM   #7
10091989
Drives: 135i FBO
Im running 42lb/hr injectors and they are about maxed out hitting 23psi.
But for me, thats perfect.
      02-01-2017, 01:38 PM   #8
2jzn54
where'd you get the injectors from? i imagine you didn't spend $350 on a set of 6 injectors.
      02-06-2017, 02:54 PM   #9
10091989
Drives: 135i FBO
I got them from Jegs and they are 39lb/hr. Cost me 180 after tax.
      02-06-2017, 03:45 PM   #10
2jzn54
mm ok. thats probably the one big downside to using the ls7 style injectors.. i personally can't find decent sized ones at a reasonable cost.. 39 lb/hr won't cut it for me.. really need to be in the 50+ range to be worth it. all of those options are $350+ though i think i might be able to snag some 85 lb/hr ones cheaper at $320 somehow lol.
      02-07-2017, 09:55 AM   #11
Sshec152
Take the part# from jehs and get them from summit, they're only around 280 for all 6 on summit
      02-08-2017, 10:35 AM   #12
2jzn54
good find.. was only seeing that price for the full length injectors on summit a few days ago thx
      02-09-2017, 02:49 PM   #13
10091989
Drives: 135i FBO
Or you guys can buy the ECS kit they sell from EOS.
Its basically everything else you need for the PI manifold.
https://www.ecstuning.com/b-evolutio...kit/b1006~eos/
all the hardware will work with the SC mani btw.
      02-09-2017, 04:50 PM   #14
FEDE/E92
Drives: 2007 BMW 335i
Where you go to buy the actual IM?
      02-09-2017, 07:35 PM   #15
BeastMode335i
Maximus Decimus Meridius
BeastMode335i's Avatar
Drives: F30 335i
awesome..
F30 335i
Melbourne Red Metallic
M-Sport Package
      02-09-2017, 09:01 PM   #16
Sshec152
There is a group buy going on right now on spool street dot com. Its $540 shipped and about 3 weeks out.
      02-10-2017, 11:19 AM   #17
10091989
Drives: 135i FBO
Alright guys and gals,
Here are the Dyno results for the Sharp Customs on my 2010 N54 135i.
My last dyno without PI made 498WHP and 516TQ, on E65 Fueling and 21.5Psi of boost w/13.8 degrees of timing. This was the ABSOLUTE MAX i could run with the stock HPFP. This was also on a lean target of 12.9 at redline. That is fairly lean which gets scary for reliability and knock.
This is a FBO car with a stage 2 LPFP and only STAGE 1 VTT Turbocahrgers. 14T Compressor wheel and stock rotor.
My current Dyno made 526.22WHP and 592.61TQ, on E70 fueling (winter blend) and 24.0Psi of boost w/ 10.8 degrees of ignition advance. NOTE: Trebila is tuning my car and hasnt increased the timing yet to test the current tables. He is going to send me a flash that increases timing after i send him more logs. So there is likely more WHP on the table once i get a better timing situation. So these are preliminary numbers.
The biggest thing you will notice is the availability of WHP is much sooner than my last dyno. I have 500whp+ from about 4500rpm to 6000rom. My prior Dyno had 498whp only near 5950rpm as a peak. So the usable whp is WAY better with PI and the manifold
I have attached my old dyno next to my new dyno to show the usable whp/tq difference.
      02-10-2017, 12:59 PM   #18
TEC
Drives: 355
Looks good!
Can we see the entire dyno sheet from both runs? Its hard to tell where things take off with only a section shown.
Also, forgot to ask, will that fit under the stock air box? I like the sleeper look and would like to maintain it if I can.
      02-16-2017, 03:52 PM   #19
10091989
Drives: 135i FBO
I cannot confirm the stock airbox will fit. I would likely say no to be honest.
The above Dyno chart shows the full dyno runs of each so idk what else you are looking for
      02-16-2017, 05:11 PM   #20
conrad325i
conrad325i's Avatar
Drives: 2008 335i
So this is fueling in conjunction with the stock injectors correct?
Could you run methanol injection thru this manifold?
Im new to the N54/5 game... I had an N52 for a while but obviously they are untune-able.
| H&R Coilovers |ApexArc-8s| M3 ControlArms | RogueTransMounts | AFEDualCone | ERChargePipe | TialBOV | ETSIntercooler | 335isClutch | BMSCatchCan | UUC EVO3 SSK | MichelinPSS | CobbAP | JB4 |
      02-17-2017, 04:12 PM   #21
10091989
Drives: 135i FBO
Yes that is correct. To run methanol you would need an injector that is capable of doing so. There is a difference between them, but the Bosch EV14 series have shown to handle methanol without corrosion.
      02-17-2017, 04:13 PM   #22
10091989
Drives: 135i FBO
the group buy is almost closed.
Its located on Sp00lstr33t.com
Remove the numbers and add in o and e's.
Reply
Tags
fuel, hpfp, lpfp, meth, port injection
e90post
