Help! Insect/Animal (I Think) Noise From My Engine Bay!
01-29-2017, 04:21 PM | #1 |
Rep 666
Hi all,
This is somewhat urgent. I had pulled my car into the garage for the evening when I noticed this screeching coming from the engine bay. When the car was in the driveway, I dismissed it as a hawk up in the trees somewhere. But, from the video, it's obviously coming from the car. The sound only happens when I'm silent, and is spaced 30 seconds to a minute apart. The car is turned off and in sleep mode (start button light turned off) while I hear it. I opened the intake box but nothing was there. It's an 07 E93 335i with no issues (that I know of). I don't want to close the garage with something in the car. I have two cats, but they are useless hunters. Is anyone here an insect specialist or have heard this noise come from a car before? Thank you! (Click to play, make sure your volume is turned up) http://vid1092.photobucket.com/album...psymzdaxze.mp4
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
01-29-2017, 05:04 PM | #3 |
Rep 665
Is the noise is coming from where you have the camera pointed? If so, the only two components I can think of in that area which might make a wierd noise like that are the water pump and the HPFP. I've read that the water pump will cycle once the car is off to cool the turbos. Maybe try the water pump bleed procedure to see if your water pump is making any weird noises (hard to tell when the engine is running). I guess it could also be a vacuum or PCV leak causing the sound. Mine make a groaning noise from time to time but yours sounds more mechanical / electronic.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
01-29-2017, 05:12 PM | #4 | |
Rep 666
I'm still hearing the noise, but it has changed pitch. Interesting! I've owned this car for years and haven't heard this before. I may disconnect the battery and see if anything changes.
01-29-2017, 05:53 PM | #5 |
Rep 110
Super strange sound!
I was thinking the throttle body since it's electronic, but doesn't make sense why it would make a noise when car is off. I wonder if it is related to the HVAC system? Just a thought. We have a Nissan Leaf, and while it has a completely different HVAC system, heat pump and all, it makes some funny noises after shutting it down. Similar to what you're hearing but not as loud and the noise lasts longer. Maybe there is something wrong with mine, but it is so intermittent I can't make it recreate. Anyways, disconnecting the battery is a good thought. See if the noise persists. Good luck! |
01-29-2017, 06:01 PM | #6 |
Rep 535
Not an animal or insect, but probably something with HVAC valve/pressure related
Corno_Baldwin27.50 |
01-29-2017, 07:00 PM | #7 |
Rep 666
Well, I went to disconnect the battery but haven't heard anything. I'll chalk it up as a fluke. Just really didn't want a bug or animal to be inside the house.
01-30-2017, 09:36 AM | #8 |
Rep 293
Drives: 2008 E93 M3
I spend a lot of time in my garage. With two BMW's and an Audi making all sorts of noises while they are sleeping. You'll hear things. Clicking, high pitched whines, grunts and groans...they are just restless sleepers. My 328i makes a noise just like yours, that goes on for a minute and a half and then stops.
01-30-2017, 12:03 PM | #9 |
Maximus Decimus Meridius
1132
Rep 4,586
Yeah i think sometimes i have that problem..! Almost liked there's a raped ape under my hood.. I'll try to scare it outta there by flooring the gas pedal but it just starts screaming and flyin by everybody..!! Then when I let off the gas I could of swore I heard it sneeze..!! Crazy!!
F30 335i Melbourne Red Metallic M-Sport Package |
Flyboy161287.50 |
