E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > TBI Question
Reply
      02-08-2017, 01:47 PM   #1
bartbes
Drives: e92 335i
TBI Question
Hey guys,
My new hpfp is just a little bit to weak for the tune I am running so TBI seems like the perfect solution. I was wondering if any of you guys running TBI could share some info, like pros and cons you are experiecing etc.
Thanks!
      02-08-2017, 03:19 PM   #2
NA55
Drives: 335i
TBI works well, but may need extensive tuning to make it work for your situation.. what is your current fueling setup, ethanol content, and whp?
bartbes48.00
      02-08-2017, 03:35 PM   #3
bartbes
Drives: e92 335i
N54 Pure stage 2, Fuel-it stage 2 lpfp, 93oct/E15, no meth. I don't know how much power it makes, did'nt take it to a dyno yet.
      02-08-2017, 08:24 PM   #4
NA55
Drives: 335i
How much boost are you currently running and what's is your ultimate goal?
You should be able to safely run 22 psi on e40 with pure turbos with stage 2 LPFP without TBI OR PI..
      02-08-2017, 11:54 PM   #5
bartbes
Drives: e92 335i
I am running about 23psi tapering to 20 with a new hpfp and it is strugling. I am running a flash tune only and I like how it is, just want to keep my hpfp healthy, and have the option to increase ethanol content to about E40 in summer.
      02-09-2017, 10:01 AM   #6
FCobra94
Guest
n/a
Drives:
Logs?
Try the VTT single barrel and give us a review once it's installed
      02-09-2017, 11:02 AM   #7
bartbes
Drives: e92 335i
I think I prefer TBI
http://www.datazap.me/u/bartbes/wedg...g=1&data=21-22
      02-09-2017, 11:39 AM   #8
itsjwilly
Drives: 2009 E93 6MT Sport
I'm in a very similar situation. Not sure how close I am to HPFP limits but current setup is a custom flash at 20.5psi for 93oct only and you can see mods in my sig. I even bought TBI, but have not installed because I think doing an e30 or e40 blend will be more reliable and easier to get tuned to my power goal of 500whp. As far as I have read, TBI really was intended for full e85 setups where octane was not the concern, just volume. I'd rather not add another system and additional failure possibilities to the car if I don't have to.
2009 E93 6MT Hexon RR600 / TTFS Custom 93 tune 421 rwhp.443 lbft (DynoCOM) / Fuel-it! stg 2 / RB inlets / Æ Exhaust / N54tuning DPs / MechTuning 5" stepped FMIC / ER CP w/Tial BOV / RB PCV / KW v2 / AG M359 / Z4 35i front rotors / BMS SSK
      02-09-2017, 11:58 AM   #9
FCobra94
Guest
n/a
Drives:
But you also have upgraded turbos...for that reason your logic on fueling goes right out the window.
If you want to "be sure" how close you are to the HPFP limits, try logging.
      02-09-2017, 12:48 PM   #10
itsjwilly
Agree I need to log on this current setup. What part are you saying goes out the window? Assuming adding 2 psi to my current set up would put me in OPs position, I would want to use some e85 to gain some power instead of try to feed more 93oct with TBI (which I don't think would work anyway). I understand e85 means needing more fuel, but e30 wouldn't warrant that much more volume, would it? Is there something I'm missing?
      02-09-2017, 10:58 PM   #11
NA55
Drives: 335i
Fuel system looks healthy.. no need for TBI unless you plan on more ethanol or more aggressive tuning..
Log looks safe... who tuned it?
      02-09-2017, 11:49 PM   #12
bartbes
Drives: e92 335i
QUOTE=NA55;21251620]Fuel system looks healthy.. no need for TBI unless you plan on more ethanol or more aggressive tuning..
Log looks safe... who tuned it?[/QUOTE]
Don't you think hpfp will suffer if it keeps dipping to 1000 and below? I think i'll just use boost per gear since it can't handle the power in 1st and 2nd anyway, and cap 3rd at 21 psi.
Wedge tuned it, I realy like it.
Still looking for opinions on TBI
      02-10-2017, 09:37 AM   #13
FCobra94
Guest
n/a
Drives:
Go over to the "other" n54 forum...a lot more users there.
Reply
e90post
