Help IDing a few things in my engine bay
02-10-2017, 09:56 PM | #1 |
N55 noob
30
Rep 114
Drives: 2011 E92lci 335i
Hey guys, apologies for the noob questions here. I've look on realoem but can't get a solid answer.
Is this a bolt that is helping to hold up the headlight unit? There is a rubber stopped on the other side. This is the same side that I have xenon vibrations and the 'stuck-left' lazy eye adaptive headlight issue on: What is this sensor supposed to do? It is capped. On the other side of the car there is a similar sensor that actually has a sensor attached to it (don't have pic of that one): |
02-10-2017, 10:10 PM | #2 |
Rep 225
Drives: 335is e92
Was that cable taped on the engine cowl on the driver side. If so it is the prewiring for the hood closure sensor for the factory alarm. Which bolt are you referring to?
02-10-2017, 10:17 PM | #3 | |
N55 noob
30
Rep 114
The other picture, I'm referring to the silver colored on that is on the fender. It has a piece of brownish metal being used as a washer underneath it. |
02-11-2017, 04:50 PM | #7 |
N55 noob
30
Rep 114
02-11-2017, 06:41 PM | #8 |
Rep 2,109
http://www.realoem.com/bmw/enUS/show...diagId=41_1706
should be number 14 there but you may need other things that go there. Well this is interesting, the right side (passenger side) is using left handed bolts there according to above link. Last edited by PhaseP; 02-11-2017 at 06:47 PM.. |
02-12-2017, 03:23 AM | #9 |
N55 noob
30
Rep 114
You're a saint, thank you!
