E92 335i Headgasket
02-16-2017, 12:07 AM | #1 |
Rep 4
Drives: E92 335i 2009
E92 335i Headgasket
hello everyone,
i have e92 335i 2008, recently i had a coolantleaking from the headgasket to the floor not internally. a week after replacing the headgasket which was toasted, everything was fine until i started get oil level low warning and low coolant warning,engine fault and started to hear a loud noise from the engine,however no overheating. i opened the oil filler to see there's coolant in it, now im thinking that the headgasket is not installed properly or the head itself have crack or something, the garage told me that the head was already checked and its in perfect condition and the headgasket is new and cannot be misinstalled. he is telling me that it could be the oil housing is leaking from inside , not the oil filter housing gasket or the headgasket. can anyone explain what could it be ? picture of the oil filter hosing picture of the coolant in oil i've already checked the engine block for cracks and found none,the noise turned out to be the bearings of the crankshaft are gone and need to be replaced. Thanks |
02-16-2017, 12:20 AM | #2 |
Rep 960
yep most definitely could be the ofhg.
I've never even heard of a head gasket fail on a n54. with the crank/main bearing shot who knows what else is shot. Sounds like a ticking timebomb/money pit. how long have you had the car? was it ever overheated ? |
02-16-2017, 02:32 AM | #3 |
Rep 337
It's very possible that one or both of the gaskets at the OFHG are bad. However, even if you get them fixed, the engine might already have sustained other serious damage, above and beyond just the bearings.
A new engine is too expensive. A used engine is a gamble. A built engine by Motiv or ABR if you want to push beyond 600whp. |
02-16-2017, 04:48 AM | #4 | ||
Rep 4
i bought it used now its 90K miles. it turned out that the headgasket was replaced by the previous owner of the car and it wasn't genuine , the engine was already opened too!! (as the garage guy told me). can't tell these when you purchase a used car anyway. my luck! now after removing the engine and having to replace the crankshaft bearings, i'm going to do the following: (almost an Engine rebuild )
here's some pictures: Engine bay Engine Out Head Finished Block refreshed any advices to take into consideration during this fuckedup situation |
Bimmer 808170.00 |
02-16-2017, 05:51 PM | #6 |
Rep 162
+1 for build thread
| H&R Coilovers |ApexArc-8s| M3 ControlArms | RogueTransMounts | AFEDualCone | ERChargePipe | TialBOV | ETSIntercooler | 335isClutch | BMSCatchCan | UUC EVO3 SSK | MichelinPSS | CobbAP | JB4 |
02-23-2017, 11:45 AM | #8 |
Rep 191
I've gone through 2 head gaskets over the past 2 years, care is in the shop right now and it turns out the head was warped so they're resurfacing it....thank God for warranty
2009 BMW 335i 6MT/MHD Wedge Custom E60/VTT Inlets/VRSF DP's/VRSF 7" HD FMIC/Boost Concepts FPM-1 E85 Fuel Pump/BMS DCI/BMW PE/ER CP/Tial BOV/BMS OCC/RB PCV/19" Gunmetal Forgestar F14's Deep Concave/Michelin PS4S/Ohlins R&T Coilovers/Swift Springs/Spec Stg 2+/Icon Motorsports M3 Rep Front Bumper
Tags |
n54 335i |
